You gotta go threw a kinda "check list" when this happens.To start off is filter clogged then remember your choke, maybe drain the carb bowl spray some cleaner in it ,or better yet clean it completely and while its out check your reeds make sure they are fine,take spark plug out check for correct gappage maybe clean that up with fine grit sandpaper.That should be good ..best of luck
SOURCE: how to remove water pump from honda 450x 2007
Remove impeller using a 10mm socket. It is a standard thread so nothing special needs to be done.get back to me if need more info
