Question about Canon PIXMA MP530 All-In-One InkJet Printer
I can't get the cartridges to lock in place canon mx310
I lost my book
    President:
  • 2,110 Answers
Error U163
I can then help you with your specific problem.
Error Code U163 (Ink Cartridge Empty or Low)
First of all, Yes, this is a common problem.
When you open your printer up, by lifting the Scan Cover, you will see lights blinking for the cartridge that is low or is empty.
1.) A lamp blinking once every three seconds means your cartridge is low.
2.) A lamp blinking once every second means your cartridge is empty.
Using your printer with an empty ink cartridge is capable of harming your printer, according to Canon Engineers.
Until such time as you can replace the cartridge you can use the method described below to temporarily turn off the error message.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Feb 28, 2011 | Canon PIXMA MX310 All-In-One Printer
Tip
Error Code U163
[Although specifically written for an MX310, this should work for all MX and MP series Canon printers.]
If this Tip does not work for you, please notify me by accessing my profile page at here and using the Ask button to write me a note.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again.
Regards,
Worldvet
NOTE: If this doesn't resolve your Canon problem and you want to try another Tip that may work, you can try this Tip written by Darklord. At least give it a read, it has been known to reset some Canon printers.
on Oct 19, 2008 | Canon PIXMA MX310 All-In-One Printer
How do i install the black ink cartrage
Hi!
Follow these steps in order for you to install the any ink on your canon Pixma mx310:
1) Make sure that your printer is turned on. 2) Lift the scanner at the front. It will rotate towards the back and it will give you a view of where the ink cartridges will be. 3) Once the print cartridges are in its final location you can push down the front of each cartridge that you will replace and pull it out. 4) To place in a new cartridge place the new one in its respective slot and this time push the front up to lock it in place. 5) close the printer top or place the scanner back in its place.
That is all you need to do.
If you have any more questions feel free to come by again here at fixya.com
You have a great day.
Feb 11, 2011 | Canon PIXMA MX310 All-In-One Printer
How do i change cartridges on my mx310 multifunction canon?
Here are the steps to change your ink cartridges.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area
Installing ink cartridges:
  1. Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Feb 09, 2011 | Canon PIXMA MX310 All-In-One Printer
I have an error - "cartridge jammed" pop up window advises to re
Please refer to Canon web site for specifics on resolving cartridge replacement and error 5100.
There's even pictures to help.
Apr 11, 2010 | Canon PIXMA MX310 All-In-One Printer
I have never had to change the ink cartridges till now and can't find the manual. The site says that they don't have a manual for the MX310 and I can't figure it out.
Hello !
To change the ink cartridge(s) in your printer,
Lift the scanning unit (printer cover) with both hands.
Pull the scanning unit support down into place.
The cartridges will move into place.
Remove the cartridge.
Take the new cartridge from the package.
Remove the strip from the cartridge without touching the metal back.
Insert the cartridge.
Hope this helps.
Oct 04, 2009 | Canon PIXMA MX310 All-In-One Printer
How to change the ink in a Canon PIXMA MX310?
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
May 27, 2009 | Canon PIXMA MX310 All-In-One Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
MX310 error code U163
Can you tell me, have you replaced the empty tank with a full one? And, have you manually reset the ink level function by pressing Stop/Reset for a full 6 seconds (one second longer than described in your manual?)
If you have, and you still see the ink cartridge light flashing, does it flash every second or every three seconds?
The contacts for the ink cartridge are easy to contaminate by accident. Sometimes wiping the contacts off with alcohol will clean them enough for the ink level to be recognized.
Now, and yes, this is a common problem. Press and Hold the Stop/Reset button for 6 full seconds again after cleaning the contacts and then release it? Use the one Mississippi method of counting.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again. Okay?
How long has it been since you purchased this printer?
Regards,
Worldvet
Oct 15, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
old marine
old marine
