Question about Olympus EVOLT E-500 Digital Camera
In low light my flash stops working, pictures are fuzzy and dark
I shot a wedding reception in a medium lit high ceiling hall. My E-500 worked well when the lights were on for about 1 hour for family pics, Then when I did candids and they turned the light down, it started acting up. I just got a larger external flash that mounts to my camera, but I had it on an extemed arm attached with a shoe cord. (Sometimes it would not go off or it would delay and the pictures would be blury and dark. During the first hour its would delay and the flash wouldnt go off, I changed the batteries on the camera and the flash, that helped for a few mins, then it would be very random, it would work perfect one min, then I would move to the next shot and it would freeze..Im new at this stuff so I need any suggestions on what might be happening. It only does it when its dark and low light. I have a wedding in March at the same Hall and want to get this fixed. I didnt know if its something that needs to be fixed on my camera or what. I shot very fast and not sure if Im over working the camera and flash.. Please Help.
-Photo Girl
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Change to center point focussing and boost iso a little
Posted on Apr 07, 2009
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
https://www.hunker.com/12003281/how-does-a-ceiling-fan-speed-control-work
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
Grainy pictures
You have likely set the camera to shoot photos in low resolution, or high ISO or both. Check your camera manual for detailed instructions on how to set these options.
If you don't have your computer manual, you can download one from this page at Canon.com. This is for the Powershot S500, this is the same camera as your IXUS 500, they just gave it a different name in different countries.
Always set the camera to shoot in the highest quality resolution mode. Memory cards are relatively cheap and you don't want to end up getting that photo of the lifetime but because you shot it in a low resolution mode you can't get a good print!
If you are shooting in low light the camera may be automatically boosting the ISO. There are only 3 ways to shoot in low light:
1) Flash - only works when your subject is relatively close to the camera.
2) Increase the ISO which results in noise in the dark areas of the image.
3) Use a tripod and a long shutter (slow shutter speed).
Dec 19, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
I have a Canon 5D and a 430EX flash. When shooting pictures my flash will delay way to long before I can shoot another picture with flash. One picture is good and 3 are dark. My flash card is a...
The 430ex flash is E-TTL, that means it adapts is power to the scene. If you shoot a scene at 10 meters, the flash will choose to flash at the max power, and will take time to recharg. Try to get closer to your subject, and remember that the flash can only lighting your subject, not the whole scene.
Dec 14, 2008 | Canon EOS-5D Digital Camera
Indoor shots such as a wedding
Have you thought about using the flash??? In low light you may not be able to hold the camera steady enough to take pictures without using a tripod.
If you want to change the colour ballance of the camera, look in the user manual. It is a little bit involved. I would recomend using the flash instead.
Jerry G.
Jun 30, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Cybershot D40
Ceremony meaning - inside church/hall -yes Insufficient light therefore long exposure in the auto setting. You should have moved up the ASA setting a couple perhaps
Aug 14, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
INDOOR PICTURES ARE TOO DARK
try using the night shot it will go slower but it works well for dark pleases
Dec 17, 2006 | Aiptek MPVR Digital Camera
Focusing Problems
* Get AF off the shutter release and onto the * button using the custom function. * Use the center focus point only. Force yourself to pick what you want in focus, AF, then recompose and shoot, a habit far more effective than computer driven multiple AF points for just about everything. * AF performance degrades in low light no matter what camera you own. This is life. At least if you control the when/where of AF, you can try and choose high contrast points in the scene to focus on, points that will help mitigate the low light. * Not sure if this applies to you, but it does apply to many a pixel peeper...if something prints sharp at 8x10 or 11x14 then AF has succeeded even if it's a little off at 100% in Photoshop. AF is not perfect and the tolerances are not necessarily up to producing 40" enlargements, which is what 100% in Photoshop is. Having said that, in good lighting with good target contrast the AF on your 20D often will nail focus so perfectly that it will hold up even at 40".
Sep 14, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Olympus EVOLT E-500 Digital Camera Logo
88 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
