Question about U.S. Robotics (USR8200USR8800KIT)
HELP. i was fine with my laptop and msn before my router broke. and i had to send off for a new sky modem. Now when i run msn it says key ports . and it wont repair. Im unbelievably getting stressed and im having to use these stupid internet messengers but their giving me viruses.
  • 68 Answers
Go to htpp://xviruslab.blogspot.com and download Quick Heal Anti Virus Plus or Quick Heal Total Security(PC to Mobile Scan, Antiphishing and Data Theft Protection) as per requirement.
mail me keerthyinfo@rediff.com
if you're facing any problem
Thank you
Bye bye
keerthy
Posted on Oct 02, 2009
I have just bought a Dynex [DX-E402] router and i'm trying to connect my laptop and pc to the same internet through it but its not picking up any internet access. If i connect my pc directly from my...
The modem has likely assigned it's IP address to the MAC address of the PC.
We need it to assign an IP address to the WAN port MAC address of the router!
When you hook up the router, the modem is no longer sending data to the correct MAC address.
Unplug the power to both the modem and the router.
Power up the router FIRST, and wait for it to complete it's initialization.
Once the lights have settled down on the router, power up the modem.
Wait for it to fully initialize.
NOW turn on your PC or laptop, and everything should be working just fine.
If not, post a reply or add a comment to this post, and I will try to further assist you.
Jun 24, 2011 | Dynex DX-E401 Router
Idk what 2 do w/ this iview netbook my daughter just got for christmas! i have comcast internet. that modem did go into my desktop but my desktop just broke so now comcast modem runs to a belkin wireless...
Under WAN settings: Enable Dynamic and Hostname : http://www.comcastbroadband.co.in (If above settings not works clone computer MAC address and assing to WAN port) You have to wait for 3min to max.then it will works. Step 2: By default DHCP enabled and IP will assigned to your computer and all connected devices. Step:3 First time you have to login with comcast website it may computer or laptop or any other device
Simply copy the WAN configurations from your laptop to your netbook WAN settings
Dec 22, 2010 | ASUS Eee PC 1000HE Netbook
Belkin router
Hi Friend,
When you are tring to connect in wireless it will ask for password,please follow the below steps and get the security key of your Router
Step 1:Connect the Modem to Router (in the Port named Modem) and take another ethernet cable abd connect one end to the Router(in the port named Wired) and other end to any one of your computer
Step 2:Open an internet explorer and type 192.168.2.1 and click on Enter button in the keyboard
Step 3:Now you will be able to see the belkin router setup page
Step 4:On your left hand side click on Security,it will prompt for a login password,leave it blank and click on Submit.
Step 5: In this page you will be able to see the security key or PassPharse,please make a note of it and type the same when its asking for security key
Regards,
Aysaam
Jun 07, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I am trying to set up a new laptop i think i
This is what you have to do. Connect the Modem that came from the ISP to the WAN port of the router. Use one of the cables running out of the LAN port of the router and connect it to your laptop. Once you do that, go to the web interface of your router and run the setup . This should work
Thanks
Ranjit
Dec 31, 2009 | Computers & Internet
Msn key ports will not fix!
Dear Friend,
First of all, always check the status of your web browser before signing in to windows hotmail messenger.That means that if you try to sing in, be sure that work offline mode in your browser is not checked.Secondly, have you run the MSN MESSENGER port configuration?Third and most important, have you opened the ports in your firewall?
Here is the list of thee ports that MSN Messenger uses:
1366 MSN Messenger
1367 MSN Messenger
1838 : TCP MSN Messenger (Gamevoice)
1863 : TCP/UDP MSN Messenger primary (incoming)
5190 : UDP MSN Messenger (incoming)
6891 : TCP MSN Messenger Filetransfer (incoming) - ports 6891 - 6900, one port per file transfer
6901 : TCP/UDP MSN Messenger Voice Telephony (incoming)
5004 : UDP MSN Messenger, ports 5004-65535. Used for AUDIO and VIDEO. Caution: securty risc! Do not open ALL these ports!
5004 : UDP MSN messenger (dynamically uses a port in this range 5004 – 65535 - requires uPNP in your NAT router and/or firewall). Used for AUDIO and VIDEO. See Microsoft website for details....
Good Luck!
Jun 22, 2009 | U.S. Robotics (USR8200USR8800KIT)
Connection problems using ethernet cable
your modem or router has othere lan port or not if there then put it and in laptop you using dhcp or by manually given ip address what is that you have to give the same in the desktop and pls off the firewall of the desktop computer
Jun 02, 2009 | Computers & Internet
XP wont connect to internet through Sky Sagem Router
NO Internet
· reinstall drivers first including the network adapters.
· power cycle the modem and router (turn-off the modem and router, and wait for 10-15 seconds before powering on the modem first, then wait for 3-4 solid lights before you turn-on the router; check a website, or else
· bypass router (by directly connecting your computer to the modem)
· checked a website
· checked the IP address by clicking start button for winXP, click run and type cmd, on the c:> prompt type ipconfig then hit enter, get the IP: if the IP address starts with 169.254.x.x…the type ipconfig /renew…or else type first ipconfig /release, then type ipconfig /renew.
· If media is disconnected, check the modem cable that runs at the back of the computer, unplugged and plug it back, or try other cat 5/ modem cable.
· Check the device manager for network adapter (is properly working), by right click on my computer, click on properties, and click on hardware tab, and click hardware manager button, click the plus sign next network adapters, makes sure there is no markings such ? ! or X marks, or else install the device manager for the Ethernet card.
· Type Ping google.com, check if the it receives and sends packet, if it does, then check the browser…
· Check browser settings, delete cookies, temp files on general tab…(click on tools->internet options), click on the connections tab, the make sure it is “never dial a connection”, check the LAN settings, make sure that there is no marks or checks on the boxes..click ok. Click on the advanced tab, click on the button “restore defaults”. Hit apply and ok. Close the browser, and open it up again and check for online website.
· Once connected, install back the router, if the there is no website shown, please your router brand support line for the reconfiguration of the router.
Apr 27, 2009 | Computers & Internet
Port 80
i think you not do configuration your router or modem so this problem will happan do one thing re configure the router and give the right configuartion and first check the dns vaslue is correct it .
Jun 02, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Wireless router setup
is the problem that "nothing coming from the modem to the router"
if the router has more than one Lan port try the cable from the modem to the router, in the first lan port or the last port.
if its a wireless problem,ensure wireless is enabled on the laptop and the router,if you set up a security key ensure that it is put into the laptop wireless setting
sometimes you need to turn on the modem first then turn the router on after a little while to sort the ip address out before trying to connect the laptop, in the first instance.
hope this is of some help but more info would be good
good luck
Terry
Mar 27, 2008 | Computers & Internet
Exactly ASUS WL-500g, no internet connection
My advice and personal experiences with both wired and wireless connectivity, is if you wish to share files and internet connection, purchase a combined Modem/Router and not a seperate router to work along side your original modem. Your modem will send your router an ip address in turn your pc is sent one from your router and can get complicated; keep it simple! These are much easier to set up and control as one unit and if there are ever any connection problems you will know it's either a setting or a modem/router problem and not have to wonder ; is it the modem?; Router? settings? etc. As there are frequent loss of connections both internet and LAN it makes sense have one peice of equipment to maintain.
Dec 22, 2006 | ASUS WL-500g Wireless Router (WL500GDLX)
U.S. Robotics (USR8200USR8800KIT) Logo
219 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
