Question about Video Game Consoles & Games
Open the ps3 case
WHERE ARE THE RELEASE POINTS TO OPEN THE PS3 CASE.?
    President:
  • 2,653 Answers
There are no release points like the xbox. You just need a T10 Security Hex to take off the top cover and then just a regular phillps screw driver for the rest of the screws. Here's a guide:
http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm
Posted on Feb 23, 2009
My ps3 160gb will need assistance how can i open it???
A PS3 can be opened rather easily, but if your PS3 is newer, or still has a warranty on it, I wouldn't open the case. If you're unsure of whether you still have a warranty on it, you can call 1-800-345-7669 and they will give you instructions. If you open your case, you WILL void the warranty. That being said, here goes:
1. Locate the side of the PS3 with the HDD symbol on it(The left side of the PS3). Above the HDD symbol, there is a sticker that covers a plastic cover. Removing this sticker will void any warranty still on the PS3.
2. Peel off the sticker and gently pry the plastic cover out. There is a recessed area with a screw at the bottom, use a small screwdriver to unscrew it.
3. The plastic cover on top of the PS3 is now loose, and you can slide the plastic cover towards the left side of the PS3(where you just removed the sticker) and lift it off.
4. There are 8 screws holding a second plastic cover down. Unscrew them with a Phillips head screwdriver, and set them aside. Lift the cover straight off, and set aside. You have now opened your PS3, and have access to the Blu-Ray player and other internals.
Good Luck!
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
Ps3 doesnt display on my tv on regular plug and shuts off after 2 mins
The PS3 combines the features of a game console and a Blu-ray player in one device but like many highly sophisticated devices it can easily overheat. An overheating PS3 displays an LED on the front called the "yellow light of death" and shuts itself off after a few minutes. Repairing a PS3 system so that it doesn't overheat can be done at home, although you will need to open up the case and add heat dissipation paste to the GPU and CPU chips inside of the case. But it costs you more rather you can send the unit to SONY.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
With a game disk in the ps3 instead of booting and starting the game the ps3 goes to the icon screen and I cannot get the game to start.
Hi.
This is a common problem on the PS3 unfortunately and is caused by a faulty blue-ray drive. The unit will have to go back to Sony for service.
You could try a DVD cleaning disk first to be sure that dirt on the laser lense is not causing the issue.
You can also open the case and clean the laser lense with a Q Tip and an alcohol cleaning solution.
If you plan on opening the case at any stage please ensure the unit is disconnected from its power supply.
If this fails and you are confident with electronics there are several videos on YouTube showing how to replace the drive if you choose to order it and do it yourself.
Thanks for using FixYa.
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
I can play my ps3 for around 10- 20 minutes then it freezes up durring play or while loading. how can i fix this, i have tried to move it to a more open spot for aticuate air flow.
This is a common problem on the PS3 unfortunately and is caused by a faulty blue-ray drive. Unit will have to go back to Sony for service.
You should try a DVD cleaning disk first to be sure that dirt on the laser lense is not causing the issue.
See an example below
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
I am having an issue with my bluray drive on my ps3. the system will not accept anykind of disc but will play games that were brought through the store. I am planning on opening up the case my self and...
dont... there is no need to open your ps3 at the moment....
its the update that screwed your ps3...
you arent alone with this problem, i got the exsact same problem, i even tried to clean the lens with no luck. so thats why i say dont to cleaning it, cuz it wont work.
and about now alot would say "then your lens is fried, go buy a new"
but im 10000000% sure it aint, and a cleaning wont work eather.
other fact is that i acually can load my games if im really patient and want to eject and insert the disk about a 100 times before it reads it,
and if it was fried it woulden even read the disk at all...
so just hang in there ps3 bud, and wait to they gonna release a new update that will fix it...
Oct 01, 2009 | Sony Playstation 3 (PS3) Console
Wont read or load any games or cd's
You can also open the case and clean the laser lense with a Q Tip and an alcohol cleaning solution. If you plan on opening the case at any stage please ensure the unit is disconnected from its power supply.
See an example below.
Hope this helps. Please remember to rate my answer. Many Thanks.
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Game Saints Row 2 keeps freezing at certain points in the game
maybe you should try different games? see if those different games freeze, if so, then it might be your blu-ray player in your ps3, or your ps3 might be overheating. my games froze at certain points because my ps3 was overheating, just try a few different games
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
2 discs stuck in PS3.....
I can fix this for you!
go to this link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300318746769
when you get your ps3 back it will work perfect and the discs will be out!!!
Oct 25, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Hold in ps button, switch off system, restart then go to options in menu and select eject disk.
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
1,660 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
