Question about Sony KP-51HW40 51" Rear Projection Television
Blinks 6 times kp-51hw40
I have kp-51hw40 that blinks 6 times then shuts down pictures and sound do not come on
This solution works for me ... i found a 51hw40 in the streets ... than i fix it thank you fixya !!!
Posted on Apr 17, 2012
    Problem Solver:
  • 8 Answers
Look here and see if it sounds like the solution could help you.  http://www.fixya.com/support/t129700-green_flashes_tv_turns_off
Good Luck!
Posted on Mar 04, 2009
Hi There... I have a sony kp-51hw40 and when I turn it on a green screen appears, then turns off and the standby indicator light begins to blink in sequence of 6 times each. can you help please or make...
The 6 blinks is happening be cause the set has lost high voltage and shut down due to the green CRT needing replacement. You should be able to get a replacement Green CRT from www.tvrepairworld.com
Jun 25, 2011 | Sony KP-51HW40 51" Rear Projection...
Model kp-53xbr4ct made 1998. picture was good. sudden went to center of screen and bowed up and down from center. it hade sound. turned of, now no sound. stand by flashes 6 times. unplugged , plugged back...
the video color distortion with the bowing in the center is called a convergence failure. the 6 blinks indicate a power supply shutdown for high voltage protect. the 14 blinks is just the tv trying to turn back on. you may be having to problems with the convergence and the 6 blinks or it may be related because the convergence amps can cause shutdown if they are shorted. i suggest calling a serviceman per the possible tow different failures. good luck
Jan 12, 2011 | Sony KP-51HW40 51" Rear Projection...
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
Screen turned orange, heard a sizzle sound tv
A capacitor has burned out. It may be on the motherboard or power supply.
Jul 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 6 blinks
Hi Yeooow,
I guess you read the fix for my set wth the six-blink error. If not, here's the link:
http://www.fixya.com/support/t647530-tv_couldnt_turn_no_picture
My set is a KP-53HS30, chassis number P65A-A.
I found a bulged capacitor on the "G" power supply board and replaced the components associated with that circuit (6-volt regulator). If your set has the P65A chassis, I'd be happy to e-mail you the service manual I have, if it will help.
-Dan
Sep 04, 2008 | Sony KP-51HW40 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40
next time it shuts off notice if the led is blinking a certain amount of times to indicate an error code. If it doesnt blink my guess would be a solder problem around the flyback or the yoke plugs.
Mar 18, 2008 | Sony KP-51HW40 51" Rear Projection...
My sony KP-51HW40 TV shuts off
the eight blinks indicates you have a high voltage error. you will need to replace the d board. the part number is A-1348-038-A.
Oct 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
198 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
