Question about Sansui HDLCDVD260 26 in. LCD Television
HDLCDVD2600 I am taking it off cable and connecting an antenna. What kind on antenna do I need ? Is the TV digital ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 152 Answers
Stop in at http://royalhdtv.com and click on antenna 101
by the way I'm allen so click and say hi ! Winguard gs2200 works for me here in Port Orange , Fl. 32129 I get 35 plus channels.
this link will take you dirrectly to antenna 101
http://royalhdtv.com/antenna101.htm
Posted on Dec 05, 2009
  • Sansui Master
  • 520 Answers
The HDLCDVD260 is digital. Change the signal type, in the menu, from CABLE to AIR, then run the automatic search to program in your channels.
Posted on Feb 25, 2009
What kind of antenna do I Ned and do I have to have cable for it to work
I am still using the antenna I fitted 25 years ago and it works fine for my flat tv, most new antennas will say that they are good gor hd tv, internal antennas normally have a cable built in to connect to tv but outdoor / loft ones require cable. Some homes have a wall socket for antenna feed but you need a cable to go from this to the tv.
Hope this helps
Oct 11, 2015 | Televison & Video
Esa tv digital to analog
Hi.I assume you can watch some channels, using your indoor digital antenna. As far as I know, you need an intermediate "box", or interface between the cable TV coming in, and the decoder. This has to be installed by the cable company. Between the decoder and the interface, there are two connections. One signal connection and one UTP wire connection for communication between both units.At least, that's how it works in Belgium and most other countries.
Jun 24, 2014 | ESA ET427E 27" TV
Can I use an antenna on my sharp tv catv? If so, what kind works for this tv
Hook up your rabbit ears and auto tune the TV and see what happens.
Jul 24, 2012 | Sharp Televison & Video
Need to know how to go cable free. Have TERK digital antenna
Shouldn't do, just connect the antennas into the Belling-Lee TV antenna socket at rear of set, tune channels. If you antenna won't fit, you may need an "F" connector to "Belling-Lee" converter plug. You will need an "Ordinary" Yagi VHF/UHF antenna installed though. Is that what that digital one is?
Feb 14, 2010 | Hitachi 51G500 51" Rear Projection...
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
How to convert the J53 BW to receive digital broadcast signals
Certainly you can use your TV!
The converter box needs an antenna so it can tune the channels, but it doesn't have to be the antenna that's built into the TV. In fact, you'll get better reception if you use an antenna designed for the new DTV broadcasts. Several types are available at stores where they sell TVs, and they start at under $10.
Then you'll need to connect the converter box output to the TV so you can tune it in on channel 3 or 4. I'm not familiar with your Jensen set, but I've never seen a TV without some kind of connector for an external antenna. The most common type on small TV's is a jack similar to an earphone jack. Radio Shack sells an adapter that plugs in and allows you to connect the cable from the converter box. Take the set with you if necessary so you can find what you need.
Feb 08, 2009 | Jensen J53-BWR 5 in. Portable Television
Cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Oct 22, 2007 | Onkyo TX-SR604 Receiver
Sansui HDLCDVD260 26 in. LCD Television Logo
97 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
