Question about Cooper Industries Weller Soldering Iron, Slim, for WES51, Uses Eta Tips
WES 51 LED not flash to indicate ready
Our WES 51 has been a great little iron. It has recently been acting up in that the LED flashes immediately after being turned on or not at all. The iron is sparadic in heating up as well. Normal operation is LED dark until heated up, then flashes green when proper heat is reached.
  • 202 Answers
The iron has a temp probe inside the pencil, most likley the problem. also these have problems with the powersupply but usually it won't heat if its a power supply problem. best guess would be the sensor in the pencil
Posted on Jul 07, 2009
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
Why Ariston lbf 51 lights flash rapidly
24501406-0h3kxpflbez5mdeb5anq3st4-3-0.jpg If flashing any of the 4 LEDs (see picture) means that the dishwasher discovered a malfunction. Depending which combination of LED flashes (one LED, two LEDs, three LEDs or all four LEDs) indicates the specific error code.
May 25, 2014 | Ariston Technologies Dishwashers
Sigma EF-530 DG ST - not working, on test or camera all 6 LED lights displaying. Any thoughts?
I don’t usually play with flash that isn’t built in- I prefer natural light, but...if this were me I would: A) take very fine sandpaper and very lightly go one time over all contacts for the flash and camera. B) I would also see if my button batteries in my camera needed changing. As I remember they have something to do with recognizing lenses and flash attachments. C) I would also make sure the batteries in the flash, although changed, were making proper contact with the battery terminals and might also lightly sand those as well since the flash is little used.
Jan 10, 2018 | Sigma EF-530 DG ST for Pentax TTL Flash
Led light flashes five times repetively
need make and model number in order to help.
Sep 08, 2009 | Sony KP-51WS510 51" Rear Projection...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Try this link to find cause of ten blinks. I have no idea what the cost would be.
Apr 25, 2009 | Sony KP-51WS520 51" Rear Projection...
Fix my line problem but red LED flashes five times
Hi Guys, Looks like your advise took care of the problem. I adjusted the power knobs for each of the RGB guns on my Sony 51 inch projection TV. The color looks great and I don't seem to have the blinking indicator light bugging me any more. I will be sure to suggest you folks to anyone with these type of technical questions.
Jan 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
Jun 07, 2008 | Sanyo PLC XU35 Multimedia Projector
Cooper Industries Weller Soldering Iron, Slim, for WES51, Uses Eta Tips Logo
299 people viewed this question
Top Cooper Welding Tools Experts
Bill Boyd
Are you a Cooper Welding Tool Expert? Answer questions, earn points and help others
