Question about Car APS921 Remote Starter - Keyless Entry
Reconnect remote starter
I have a audiovox remote starter-prestige APS-901 on my truck. It was disconnected . How do I reconnect it
  • Anonymous Mar 05, 2009
    I do not have an owners manual. How can I get one for the for the starter prestige APS 901. It was installed by Premium Sound and they did not give me an owners manual.
    Novelist:
  • 152 Answers
Those devices, when operating properly, are commonly not disconnected, but you could attempt to find the power lead and the in-line fuse to make those re-connections, also check the battery(s) in the remote. If the disconnection is more in-depth then you should acquire the installation and owners manual from Audiovox, so as to troubleshoot and maybe discover what else is disconnected.
Good luck...
Posted on Feb 23, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Aps51 won't learn tach
Never heard of an APS 51, Prestige Remote Starter.There is a APS 57. If it is a 57 then yes.
Jan 24, 2014 | Prestige Remote Start
I have a prestige aps 901 I just replaced the car batterie now the remote start will start the engine but imediatly shuts off what needs to be reprogramed?
check the fuse and relay to the remote start if not that then it might be the module itself if it is aftermarket it was probable shorted out when battery was changer and may need a new one
Jan 23, 2014 | APS-901 Prestige Remote Start
Battery key fob
Turn the ignition key on , open the hood, disconnect the battery for two minutes, reconnect and try .
Dec 14, 2013 | Prestige Remote Start
Have a Audiovox 901C installed and factory remote will not unlock while remote started. What wirre do I use to by pass.
There is no solution to make your factory remote work when the car is running. This is the issue with honda/acura, toyota/lexus, some fords, etc. Here is what must be done; connect the blue/black of the four pin connector from 901C to the unlock and/or disarm wire of the vehicle. This will unlock the door before start. Also, you have to connect the black/yellow to the vehicles lock wire to relock the doors during crank or, the black with green to relock the door after start. Now, you will be able to press and hold the start button of the 901C remote to unlock the doors while running.
Feb 18, 2011 | APS-901 Prestige Remote Start
Car starts then stalls I have installed a Pretige remote car starter on My 2005 Cadillac Escalade EXT. I have the bypass installed with the key in it. The truck starts then stalls. Any answers?
You have the wrong bypass. The bypass you are using is for universal transponders. You need the Passlock 2 bypass. The passlock is a resistance that is read from your ignition cylinder by the bcm that will allow your truck to start.
Jan 20, 2011 | APS-901 Prestige Remote Start
I'm looking to get the user manual for a car alarm: aps2k4sflcf.
Go to this site http://auto.manualsonline.com/manuals/mfg/audiovox/audiovox_remote_starter_product_list.html
and click on Platinum APS 686T - Audiovox Remote Car Starter Owner's Manual
and click on APS 686 - Audiovox 4 Channel Remote Car Starter Owner's Manual
Jan 16, 2011 | Prestige APS686T Remote Start and Keyless...
Prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Feb 15, 2009 | Prestige 2 Button Remote Security System...
Prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Dec 01, 2008 | Prestige Remote Start
Car APS921 Remote Starter - Keyless Entry Logo
350 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
