I HAVE PRESTIGE LAPTOP,THE LAPTOP IS WORKING FINE BUT THE LAPTOP LCD CASE IS DAMAGED,LCD IS IN GOOD WORKING CONDITION.IS THERE ANY EQUVIVALENT CASE OR LCD CASE AVAILABLE TO REPLACE IT. rameshmnaik@yahoo.com
  • 13,433 Answers
Hey,
such case maybe available at ebay
www.ebay.com
Note that the cost of replaceing the lcd case can be around the price of a new lcd display.
have a look around ebay and see if you can find the case for your spesific mode, I myself found the caseing for my older laptop there but the price was too high. over 100usd for the caseing and I didn't care enough to invest and replace.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 24, 2009
Black spot appeared on the screen on bottom left side how to clear it
A large black spot usually means the LCD screen is damaged. It may have fine cracks around the black spot. In this case the LCD screen needs to be replaced.
A replacement screen maybe available for your laptop from this WEB site.
LCD screens and Inverters www.lcdparts.net
Feb 12, 2013 | Lenovo Computers & Internet
Tip
How to detect if your hard-drive is working or not/hard disk maintenance.
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
on Oct 21, 2010 | Computers & Internet
I have a Samsung 3g 2tb harddisk and it makes strange noises. sometimes it doesnt work and a my pc freezed.
Here is what you need to know about hard drives.......
I hope this is helpful..........
Good luck.
Mar 07, 2011 | Samsung G3 Station Desktop External Drive...
I have U330 which has broken LCD CASING. LCD is working fine but casing is broken. Where can I buy replacement casing?
Hi
www.ebay.com you will probably find something on there
type in your make model and then type spares or lcd casing
good luck
please let us know if you find what you are looking for
thankyou for visiting fixya
Feb 01, 2011 | Lenovo 59-015270 IdeaPad U330-7232UDT...
Wd my book flashing blue light. sill no power up
Good luck.
Jan 22, 2011 | Western Digital My Book Essential 1TB...
Hard disk tiking when power up.
Good luck.
Jan 11, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
Last night i used my laptop and it is still in good condition. I was surprised when i opened this morning, there was already a straight white line that is seen horizontally on 0.25cm from the topmost area....
It might be the problem of the LCD display wiring. Not any problems of the drivers. If your notebook is still in the warranty period, call the customer care and they should fix it.
Or else print screen, copy it to paint. If there is no white lines in the image, then sure its LCD problem. Replace the wiring with experts in case you're out of warranty period. Take care not to repair it by yourself as it could do more damage to your screen.
Apr 17, 2010 | Dell Inspiron 9100 Notebook
SIR, I have a samsung lcd using mosfet
No,get the same mosfet IC.Mosfet dosen't function like a capacitor,capacitors up a litte voltage it no problems.
Mar 17, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Residue inside LCD screen.
Hi there.
Here is an in depth guide on how to separate the layers from the screen, it's imperative that you take extra special care while you do this repair because if you damage the screen it can be costly!!!!
http://www.laptoprepair101.com/laptop/2007/02/03/repair-notebook-lcd-screen/
Good luck
Jun 10, 2009 | Samsung R610-64G Laptop
Digital camera Fine Pix
Does this happen all under the same lighting conditions, or in low or very bright light? If consistent light, do the pictures still seem faded or blurry on the screen of a computer? if so, the sensor might be damaged, and yes a new one. If they're ok (consistent) on computer screens, then the camera lcd might be loose or damaged which means its fine but give it away and get a new one if you can't handle shooting without relying on the lcd.
Sep 13, 2007 | Cameras
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
