Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer will not lock after the start button has been pressed and held for several seconds. No error messages appear and all the appropriate indicator lights come on, it just won't lock and run.
My machine did the exact same thing. I called a technician who replaced the lock. However, when he turned on the machine it still did the same thing. I then watched as he unpluged and replugged the wires in the top right corner of the machine and surprise it was fixed! I think that the wires came loose and I paid for a part I didn't need. Try it take off the top it unscrews from the back of the top edge. Unplug the wires and replug one by one. Try to start the machine and see if it locks. I think I paid for a part I didn't need as the tech told me to do that if it gave me a code again. If you do need a new lock assembly mine cost $150 for the part and labor that I didn't really need! Good luck!
Posted on Feb 24, 2009
  • alleycat207 Mar 16, 2014
    Update on my Whirlpool Duet issue with the F11 doorlock code:My Whirlpool Duet did the same code over and over again. A repairman replaced the doorlock which is what the code indicates but was costly and NOT a fix. I finally sent my circuit board to CircuitBoardMedics.com cost $75 and has been running smoothly since. I figured this was the problem since when I jiggled the wiring connecting it, it would work again. There is a tutorial on youtube on how to safely remove the board. Give them a call! I dealt with my problem for 4 years by wiggling and unplugging wires wished I had found them sooner.
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi, I have a Whirlpool Duet dryer stuck in control lock mode. I have tried to hold the "End of Cycle Signal" button for several seconds but this has not remedied my current situation I hate to have spent...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer is stuck on control lock mode. Have tried pressing the end of cycle button for several seconds and control lock button stays on....dryer won't run.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#!#!
Jun 27, 2010 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
My whirlpool duet dryer won't go off the control lock. I've held the button down for longer than 4 seconds, unplugged the machine and still nothing??
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.)()(^$#
Oct 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet control lock light is on and the machine will not do anything. I have held the end of cycle button for several seconds and even turned the breaker of all night hoping to "reset" it.. no...
Jul 29, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a whirlpool duet dryer - the control lock button is engaged - I've held down the end of cycle button for three seconds + plus it will not release. What next?
Jun 13, 2009 | Whirlpool ET8CHEXSQ Dryer
Wont start key symol appears
May 02, 2009 | Washing Machines
Whirlpool Duet Ghw9150pw1 would not start
Aug 21, 2008 | Whirlpool GHW9150 Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
