Question about Frigidaire FRS26F4C Side by Side Refrigerator
My defy duette double door fridge/freezer started to defrost itself now i don't know which button to push to get it working again? There are three push in buttons but i don't know which should be pushed in - have misplaced my manuel
3 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: Frigidaire frs26r4a after opening and
The only thing that I can see that would cause that is a broken freezer door light switch and possibly the power going through the adaptive defrost. Broken or fused to cause the power to come on when the door is closed...Click Here=> FRS26R4A I blieve i can help you with this if you are willing to work and communicate with me, Thanks Sea Breeze
Posted on Dec 27, 2010
  • 92 Answers
SOURCE: Top Freezer and Fridge not working
WHEN ITS NOT WORKING DO YOU HEAR A CLICKING OR BUZZING SOUND (IF SO BAD COMPRESSOR OR OVERHEATING)SEE BELOW
ALSO CHECK THE CONDENSOR FAN IN BACK IS IT RUNNING WHEN THE COMPRESSOR IS RUNNING
Posted on Feb 22, 2008
SOURCE: Bought a Thor Fridge Freezer just over 10 months ago.
Last night put a bowl of water in the freezer section and turned the dial all the way to the right, Bowl is frozen over this morning so I am getting a themometer today and will set it at what other freezer makers recommend and see how it works then. I will try the water trick again and see how well it works.
Posted on Dec 10, 2008
My double door firge frezeer is not icing and the red alarm button is alarming all the time
Glori,
you mite need to replace your thermostat,...... the alarm button is
telling u that your fridge is not cold enough, there is also probably another prob but u need to b a electrician to sort it on the top of fridge there is a panel,.. under that there is a fusible link if one blows it will need to b replaced its soldered in no job for u unless ur a electrician hope this helps
Oct 24, 2013 | Red Defy Helmet Youth 2012
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
MAYTAG MBR2256KES Is a defrost timer the same as a defrost thermostat? My freezer is coated in heavy frost and my fridge won't get below 55 degrees. Thanks
with the model number you sent you don't have a timer you have a jazz board in your machine,it's a computer board located behind the touch pad where you set the temps in the fridge section and the timer isn't the same as the defrost thermostat.let me ask you this is the frost on the back inside wall of the freezer or on the ceiling and frozen water droplets on the packages,a common problem with bottom mount freezers is the door gets left open mostly from a food package in the way,you push the door in,it hits the package,it feels like the door closed but it's open and warm air gets in and freezes up the air ducts.if it's on the back wall you have a defrost problem,bad defrost thermostat,defrost heater or computer board.if it's a defrost problem remove the bottom kickplate and look for the tech sheet,it will tell you how to put the machine into defrost,i think you open the door,hold in the lite switch,press the down arrow three times on the fridge setting,let go of the lite switch,press down again and you'll see an s,prees down again and you're in defrost,shut the door,but check that on the tech sheet,listen in the freezer,the fan shouls shut down and if it did go into defrost you'll hear a crackling sound,if the compressor is still running most likely the board is bad,,i can help you out if it's a defrost problem but first let me know if it looks like the door was left open or the inside back panel is covered with like snow or frost.
Sep 24, 2011 | Maytag MBR2256KES / MBL2256KES
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Sep 11, 2009 | Freezers
KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Jan 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dec 09, 2008 | Frigidaire FRS26R4C Side by Side...
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
I own a three year old Whirlpool side by side fridge freezer with ice maker and water dispenser. Icemaker not now working, and fridge temperature warmer, not cooling food etc sufficiently
ice maker will not work,i push the handle to get ice it makes a noise like the motor is running .the water works just fine .please any ideas
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Feb 18, 2008 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Frigidaire FRS26F4C Side by Side Refrigerator Logo
281 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
