Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Odor in refrigerator/freezer
GE Profile ESS25LSNABS: odor in fridge then freezer. has been cleaned out twice/wiped with baking soda. makes water, milk, etc. smell. Cleaned under fridge-changed water filter. Threw out all things(bottles, etc.O) in fridge and freezer, currently letting it stand open to air out. Is there a filter that we can't find it (haven't been able to find our book either)? Help!!! Thank goodness we have a small fridge in garage as we can't use our current one. Any help/ideas would be greatly appreciated.
Linda
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check the drip pan
Posted on Apr 02, 2009
Problem is rotten smell inside GE profile fridge. I've checked for rotten food-none; taken everything out and cleaned inside plus all shelves with added bleach in water. Smell is still there. I...
Hi, pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. You can also mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section. Too much bleach and the smell of bleach would be circulated by the fan to the room, so be sure to add water. Finally, another popular methods of removing fridge odor include washing the entire fridge out with a vinegar and water solution, placing fresh coffee grinds or boxes of baking soda on each shelf and even using trays of cat litter.
May 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
We have a ge pds20mcr bottom freezer ref and have a foul odor coming from the bottom of ref.
If the odor is only present from the bottom of the fridge, and not inside the freezer or when it is shut, it is most likely spoiled something. Put everything in a few coolers, cover with ice and close up, spray out the fridge with some cleaner and let the freezer defrost if there is ice buildup on racks or surfaces. After the fridge is clean, I suggest using a box of baking soda to keep odors out of your fridge. Arm & Hammer recommends replacing these boxes every 30 days, but I've had mine in there for 6 months or so and it helps.
Dec 03, 2009 | GE Energy Star PDS20MCR Bottom Freezer...
Frigerator throwing off an odor
Begin by carefully wiping the door gaskets down with 2 cups of vinegar in 4 cups of water. If that doesnt solve it wipe down the entire inside of the fridge with the vinegar water and then put an open box of baking soda in their.and leave it to absorb odors.
Jun 23, 2009 | Jenn-Air JFC2089HE French Door...
Smell only when fridge is open
try putting in newspapers to draw out smell
Mar 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Odor in GE side by side Fridge
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Bad Smell in Fridge
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
Fridge odor
There are a couple of methods to help remove odors from a fridge. The first is a cookie sheet with baking soda spread across it left in the fridge for several days. The other is something called Activated Carbon. Most stores sell it as a carbon odor filter and it is pretty cheap. It actually works better then the baking soda so I recommend you pick some up and just leave it inside the fridge. You can also put this behind your fridge or wherever you have foul odors. Hope this helps.
Nov 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
429 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
