Question about Averatec 3200 Notebook
Blue screen on laptop
I can connect to the internet at other houses if I take my computer there. It will not connect at my house, it goes to blue screen then does a restart.
Why has every laptop in my house seem to have chosen my mother's laptop as their leader?
When she turns off her computer does she also turn off the wireless router? Just a thought.
Sep 11, 2015 | Computers & Internet
Why does my internet keep dropping?
change your connection system
you can get TP link units that plug into the house electrical system and run ethernet cables from the computers on a home network system
works like a charm over any distance on the same power circuit for the house
may be a wireless dongle will fix your problem
Apr 11, 2017 | Motorola Computers & Internet
How do i connect phone to laptop connection
So do you have internet service at the house? If so you can plug the ethernet cable from the modem directly into the computer's ethernet port.
If you're talking about directly connecting to your cell phone, then the phone has to have the built in router in it. If it does, you can connect your computer to it wirelessly.
If you're talking about a regular old house phone (land line) then you would be very slow if you could get it connected. I don't think the newer models of computers even have a modem port to connect a telephone line into it. But basically you would still need a internet service provider to connect it.
Bear in mind that there is a difference between the phone cord and the ethernet cord. The phone cord is smaller in size and the end that plugs in is smaller.
Apr 03, 2012 | Computers & Internet
Any computer guru in the house, please i need your help, i just downgraded my laptop from window7 to xp and after that whenever i power on my laptop after two to five minute it will display a blue screen...
New laptops need new operating system. XP drivers(year 2000) are not enough for newer laptops. You may try internet to see if there are better drivers for XP on your laptop.
Feb 23, 2012 | HP Computers & Internet
How are you doing. i have a house computer and my daughter brought over her laptop and wanted to go online but since her wireless button on her laptop is broke we wanted to just hook her laptop up to my...
if wireless wont work, do wired internet connection. buy a UTP wire with RJ-45 attach to it. plug end of rj-45 to your modem and the other end to the laptop. and setup the internet connection.
Nov 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't connect to internet
try to re-install your network driver. if still doesnt work i susptected your network card is faulty. you might need to replace it.
Jun 30, 2009 | Computers & Internet
3 netopia 2247 routers daisychained
How far are you running the CAT5 cables from house to house?   CAT5e only has a solid range of about 150ft, and anything near 100ft is pushing it.  You may also need to use CROSSOVER cables when plugging routers into other routers.
Also, who has the actual internet connection?  I'm assuming House 2 does.  One big problem is a router is your Gateway address.  And, if house 2 is the only one with a valid Internet connection (via DSL or Cable, etc), then the router in house 2 is the only "true gateway".  And, all 3 houses need to be in the same physical network (i.e. 192.168.1.0 range or whatever), and all computers should have the same Gateway address...which would be the IP address of the router in House 2.
What you really need in this situation is 1 router and 2 switches.  Put the router in House 2 and put switches in House 1 and 3.  That would be the best way to handle this problem.  It would also end your connectivity problems.
Cheers!
Jul 11, 2008 | Netopia 2247NWG-VGx Wireless Router...
Wireless Connection Difficulties
sounds like your wireless card in your laptop needs either a replacement, or new drivers.
www.sony.com
May 23, 2008 | Sony VAIO VGN-FJ290P1 Notebook
Compaq laptop won't connect to internet
on my hp the light is blue when switch is on. go to network and conn. and make sure ur wireless is turn off there. cause if my switch is in the on position and i turn it off hp wireless assistant the light will glow orange eventhough the switch is on . ? Just had an issue simular to this one, hope it helps.
May 19, 2008 | Computers & Internet
Averatec 3200 Notebook Logo
43 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
