Question about HP Computers & Internet
Cannot get logged on
I get the message ''boot disk error....insert disk and press start..............'' what disk? I cannot get logged on at all!.
  • 477 Answers
Hello, seems like your harddisk have some failure. check if bios finds your hardrive, if not check harddriver cable. if its seems ok you harddrive is broken :( contact a professional dataexpert if you have lost important data.
Posted on Feb 23, 2009
  • HP Master
  • 1,183 Answers
You need to check two things first.
1. Check if there is any cd in the cd-drive slot
2. Check if there is a floppy in the floppy drive.
If both are empty, then operating system ie. windows might have crashed and need to be either repaired on reinstalled using the cd.
So you need to check if you have the original cds like the operating system and drivers for your computer.
Thanks
Proton
ERROR : F3-F100-0003 when running recovery disc for Toshiba Satillite L755-25217
Just format your Laptop because your operating system is damage.Install another Operating System that's all.
Mar 26, 2013 | Computers & Internet
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
How can I channge event log if I can't enter set up with F2
if you want to get the event log and the error code
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
hope this helps
Jun 29, 2012 | Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
Toshiba satellite 5105-s607 insert system disk error. Every time put o.s disk in keeps saying same message.
Log into the bios and change the boot order to boot from the CD - it will then boot up your CD system Disk first
As the PC boots - you should see a message to get into bios/setup usually F10, F2 or del key varies buy manufacturer
then look for the bios section for boot order and make sure the CD/DVD drive is set to before the harddrive
Mar 19, 2010 | Toshiba Satellite 5105-S607 PC Notebook
Need help please and thank you
For that you need to fix error on harddrive.
For that You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Acer 3690
Could be various causes just follow the information below and you should solve it.
Good luck
NTLDR is Missing
NTLDR is missing
Cause:
Solutions:
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows XP users
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Oct 31, 2008 | Acer Aspire 3690-2196 Notebook
Boot error message
Do you have a disk inside your floppy drive? If you do, remove it and try to boot your computer again.
Do you have a USB hard disk connected? If you do, try disconnecting it first.
If those two things don't work, you will need to have your computer checked by a technician. Maybe there is a problem with the hard disk or with the BIOS configuration (boot sequence).
May 28, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
