Question about Canon Speedlite 430EX TTL Flash
Flash is acting weird...
I have a Canon Speedlite 430EX. I'll take two or three pictures and it works fine...then nothing. No green light. No red light. ...I've checked the batteries and they're fine. Is this a problem with my camera or with my flash?
  • zapanisth Apr 25, 2009
    Same problem...
    it works on a 400d but i had some problems on my 40D
    let me know if you solve your problem.
The problem with troubleshooting is that you have to try different things to see what changes when you do something different. Try new batteries, then try another set, then connect the flash to another camera and see if you have the same results. In my opinion, I'd have to say that it's probably the flash but like anything else, you have to try different things. Try using a different flash unit to determine if it's a flash issue or a camera hot-shoe issue. Once you find the culprit, then either replace the flash (hopefully this is the issue because it's cheaper) or it may unfortunately be the body. Hope this helps... just try a few things and cancel out what's working vs. what's not working.
Posted on Mar 26, 2009
Text is blinking on my 430ex lcd screen zoom --mm. How do I get it to stop?
Check the diffuser is fully retracted. Pull it fully out then all the way back in.
Apr 10, 2014 | Canon Speedlite 430EX TTL Flash
Canon 430ex ii seems to flicker rapidly sometimes before taking pictures
Yes it is. The system is simply measuring the flash to meter the exposure.
Dec 29, 2013 | Canon Speedlite 430EX TTL Flash
Speedlite 430EX II pilot red light wont turn off wont fire
Try mounting the flash on your camera, turn both on and reset your camera to factory default settings in your camera menu settings.
Feb 13, 2013 | Canon Speedlite 430EX TTL Flash
My canon speedlite 430ex does not charge up, batteries are new and rear screen works/lights up any ideas?
Sounds like an internal wiring circuit problem. It's strange that the screen lights up but the flash doesn't charge. You should probably get it checked by Canon.
Feb 11, 2013 | Canon Speedlite 430EX TTL Flash
When I take a promaster remote flash trigger system with my canon 430ex half of the picture is exposed. What am I doing wrong?
this is most likely a sync issue. you shutter speed is too high. try lowering it. 1/200 or 1/160 of a second should be fine for your case.
Sep 19, 2012 | Canon Speedlite 430EX TTL Flash
Just got a Canon 7D. Attached my 430EX to the hot shoe and it won't fire. Tried new batteries and checked the contacts, and it still won't work. Put th 430EX back onto my Rebel XTI, where it has always...
Make sure you using flash grade batteries and not rechargables. try energiser ultra or litiums or duracelll plus but nothing else. if the charge light is not coming up then most likely batteries. I would take it to your local camera shot and test your 7d with one of thier 430 just to make sure the hotshoe didnt short out the flashgun
Feb 21, 2011 | Canon Speedlite 430EX TTL Flash
430EX won't fire.
Can you short the pins to have the flash fired?a.l9609@gmail.com
May 27, 2009 | Canon Speedlite 430EX TTL Flash
Canon speedlight 430EX II won't fire
The conceting piece of the Flash has cracked when i dropped it, is there any thing i can do to repair or exchange it?
Jan 24, 2009 | Canon Speedlite 430EX TTL Flash
Canon 430EX Flash
I have a 430ex and S5, I don't think the zoom head will move without being mounted on a camera.
If the flash test fires ok, then it should be fine.
Oct 16, 2007 | Canon Speedlite 430EX TTL Flash
Canon Speedlite 430EX TTL Flash Logo
384 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
