Try unplugging handset cord on base part of the telephone, then plug it back in as some of these telephones had poor connections on handset cords in base part of telephone,make sure handset cord is pushed home fully in correct socket for handset and not headset.
Look at the bottom of the set that is giving you troubles, check to see if the handset is plugged into the correct spot.
It should be plugged into the Handset jack not the headset jack.
This is a common mistake.
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
make sure you are in the handset port and not the headset port. also did you swap handset cords????
cannot hear dial in on the handset
