Question about Ricoh Aficio 2015 Copier
Changed email hosting, now scan to email does not work
We have a Ricoh Aficio 2015. We use it quite a bit for scanning docs to email addresses. We recently changed our web and email hosting company (IP change also). The email (mailbox) addresses have not changed, but the host has.
Since this change... the scanned documents never make it to the email address. When I try sending to other email addresses like my Gmail account everything works.
Read the Operating Instruction book of rthe machine, but to no avail.
Any help appreciated,
Thank you,
Steven Banks
I'm confused. Are you saying that the programmed addresses don't work, but if you manually enter an address you can send?
Was your Gmail ( or another Gmail) account formerly the account to which the machine's settings were associated?
In order to use the scan to email, whatever settings have changed in your main email account, for example: username, password, SMTP & POP servers, etc, must be changed to match.
I am prettty sure you may have some difficulty, however if your new host uses Email encryption (SSL) , because I don't think that machine is compatible, so you may have to (somehow) configure an extra email account within your Outlook, or whatever you use that does not require authentication.
Posted on Feb 23, 2009
How to configure scan to email id, we are using aficio 2015
it is trick part as ricoh does not go well with pc connectivity . u have to install the scan driver through cd and follow the steps
Jun 06, 2011 | Ricoh Aficio 2015 Copier
Ricoh 1232c scan to email SSL issue
no work around for machine. you can scan to a folder on the network, than attach your doc to an email. only way to do it on a ssl.
Mar 24, 2010 | Ricoh Aficio 1232C Color Copier
Scan to email gives server response error in home network. SMTP server tried by IP address and DNS name. Port 25 Authorisation POP for SMTP. The other authorisation types give a network error straight...
I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication.
Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server.
Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
Feb 20, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Need instructions to set-up email address
There is no email or scan to email function on the Ricoh Aficio 450. I believe it only has ISIS or TWAIN scanning as an option.
Oct 20, 2009 | Ricoh Aficio 450 Copier
RICHO 2015
Make sure there are no firewalls turned on your computer. All firewalls should be controlled on a router.
Are you using the web interface from the copier to download them?
Mar 09, 2009 | Ricoh Aficio 2015 Copier
I want to do scanning on Ricoh 2015
You can either install the Twain Scanning driver - printer driver disc or use Scan to email function.
Good luck and please rate me, thanks.
Jan 16, 2009 | Ricoh Aficio GX3050N Printer
I am having trouble scanning a document on the Ricoh Aficio 2018D, I also cannot locate the user manual, can you please advise how to scan on this machine?
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at Ricoh.com, under Downloads, but this will not help very much with the scanner config.
Sorry:(
Dec 08, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2015 Copier Logo
1,898 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
