Question about Sony Cyber-shot DSC-W200 Digital Camera
Camera reset for w90 and w200 sony
How do I perform the reset..... noo, taking the battery out for 15s doesnt work.
  • 10,594 Answers
If camera is DSC-W90 and DSC-W200, go to camera menu and select Initialize -> OK
That will Reset camera to factory default settings.
Posted on Feb 23, 2009
The display has a shaky blurry purple image on the dsc w90 and the pictures turn out purple
Posted on Mar 18, 2011
How to reset sony dsc-w90 to factory setting
Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product.
Follow the appropriate procedure below for your camera. Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button:
Locate the RESET button on the camera.
Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset:
Turn off the camera.
Remove the battery pack.
Remove the button-sized lithium battery.
Allow the camera to remain without power for 30 seconds.
Reinsert the button-sized lithium battery.
Reinsert the battery pack.
Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required.
Hope this helps.
Oct 07, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Red light by the battery is blinking n doesnt turn on
Hi bklynzrealis,
Seems that you battery needs charging, if you already did recharge the battery then the battery needs replacing if the red light blinks after charging.
I hope this help.
have a nice day,
mvincnetc
Jul 12, 2011 | Sony Cyber-shot DSC-W200 Digital Camera
Turn the power off and one again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Jun 01, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Hello, my sony cybershot DSC-W200 is stuck on USB Mode since last night ( Mass storage) and doesnt want to change program or take any pictures. Is there anything i can do such as reinitialise it with a...
The same thing happened with my dsc-w220. while i was on chat to get help i tried inserting and removing the usb connector cable to the camera. i did it a 5 or 6 times. it works now.
May 18, 2010 | Sony Cyber-shot DSC-W200 Digital Camera
I have a sony cybershot dsc-w80/w85/w90. I have
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
Oct 18, 2009 | Sony Cameras
Sony W90...usb port not working (prooved the lead
HI there,
Please try to reinstall the camera driver to your PC, then try to connect again.
Regards,
Jeep Brainy
Sep 20, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Camera lens go in and out about 3 times, I cant take pictures.
1. Remove the battery and reinsert it after 30 seconds. 2. Try resetting the Camera. To reset, refer supplied Manual. 3. If stil not resolved, please get the device serviced.
Aug 06, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Sony cybershot DSC W30 buttons fail
take the battery out and let the camera sit for an hour or two, take out the memory card, try to view photos on computer, if it does not work, you will have to format the card and start over. Some times when the format on the card is bad, the camera will not work properly. I have two cybershots myself.
Mar 13, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Slow speed
If it is a circuit board problem, it can only be repaired with a replacement board.
Nov 12, 2008 | Sony Cyber-shot DSC-W200 Digital Camera
Sony Cyber-shot  DSC-W200 Digital Camera Logo
585 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
