Question about Directed Extreme XA-5001 150W x 1 Car Amp Car Audio Amplifier
The amplifier keeps on blowing out the fuse when i connect the battery
    Novelist:
  • 152 Answers
Start by dis-connecting the power lead at the amp, and securing it (where the bare wires are not touching ground) Now insert a new fuse then make the battery connection. If the fuse blows then you need to trace the power wire to find the short, or replace the entire wire, paying close attention to sharp edges and pinch-points that could cause this problem to reoccur.
If the fuse didn't blow, dis-connect the power lead at the battery then all of the other connections at the amp, reinstalling the power lead to the amp. With only the power lead connected at the amp and the good fuse inserted, reconnect at battery,and if the fuse blew then the problem is with the amp. and should be repaired or replaced depending on its value and the cost effectiveness of those two options.
If the problem has not yet been discovered, continue with tracing each of the remaining amp wires in that manner, as been described above.
Good luck...
Posted on Feb 24, 2009
Why does my inline fuses keep blowing on a jbl gto 14001 amp
You need to calculate the amount of amps being driven through that fuse + the amount you need to feed the amplifier.
In my Volvo S40 and V70 I had no problems driving an amplifier of the rear power connector, but on my Honda S2000 however I had to create a different connection all the way to the battery line for a smaller amp (connection as in cables, condensers/filters and fuses).
Feb 18, 2016 | JBL Car Audio & Video
After tapping into the ignition wire to connect the remote wire for a amplifier the 15 amp fuse keeps blowing when I try to start the car. What should I do?
a car amplifier should use an outdoor 2or so gague (very thick_) wire, ran, not to the fusebox, but to the battery, with a 20-30 amp under the hood, within a foot of the battery. the amperage your fuse will rewquire is based on the formula amps= wattsdivided by volts. a 240 watt amp on a 12 volt line would need a 20 amp fuse, just for the amp alone.
Dec 21, 2014 | Car Audio & Video
Fuse apx200m
HI,
If the fuse is blowing of then there is problem with the inverter stage of amplifier. There is an inverter stage in the amplifier to boost the 12V to + or - 30 to 40V normally. Its a switching circuit normally uses Mosfets and ferrite core transformer and a driving IC. If the mosfet is shot then the fuse will blow off immediately after power is connected.
Check on thing remove the REM connection and then connect the power. If the fuse blows the there is fault with the Mosfet Its short.
If the fuse blows only when you connect the REM then the amplifier stage is faulty.
Also check by disconnecting the speakers. if any of the speaker is faulty then there is a chance for fuse blow off.
Ajin
Apr 27, 2012 | Clarion APX280M 2-Channel Car Amp
I just replaced an amp and now the inline fuse by the battery keeps blowing
Most likely you have your power and ground connections reversed on the amp. That will cause the fuse to blow immediately upon contacting the two sides of the fuse. If the fuse stays intact for a short while but pops after turning the amp/car on and your connections are correct then there's a problem with the amplifier and it either needs to be serviced or replaced.
Dec 01, 2010 | PPI PC2600 Car Audio Amplifier
I have a 1200 w sony xplod amp, with 2 caps, hooked to my sony xplod 1200 w 15s, I just need to know what size inline fuse I need to have connected to my power wire to my battery? I have a 40A that keeps...
with no signal input the fuse should not blow ,if it blows then the amp has a short on it ,if it blows when the volume is turned up really high the try 60 amps .
Jun 18, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
KAC-8104D Car Audio Amplifier: Fuse keeps blowing why...
Most likely a bad ground connection, clean up where the ground is connected to the vehicle, check the power wire connections too, if that doesn't help route the ground wire to either the chassis or the battery to get a lot better connection, also possibly if you have the amp on full gain (max power) it may be getting a surge from your vehicle which means turn to down a little or get a capacitor.
May 16, 2010 | Kenwood KAC-8104D Car Audio Amplifier
I have an alpine m1000 amp and the fuse in the wire from the battery to the amp keeps blowing. Does anyone have any ideas?
Check that you dont have a short on the main power cable from the positive of the battery too ground
If it only occurs when you connect the amplifier... then the amplifiers power supply has gone short curcuit.
Take amplifier into a qualified repairer and get it fixed
Nov 07, 2009 | Alpine MRD-M1000 Car Audio Amplifier
Amp keeps blowing the fuses
Serious short circuit on your output transistors, need replacing.
Sep 28, 2009 | JVC KSAX4504 MOSFET 600-Watt Amplifiers...
I have a 25 wat fuse in my power wire connected to my amp and i keep blowing it. should i put a bigger fuse in it?
Hello grabert205,
You do not say if the fuse blows immediately upon powering up or while the amplifier is operating. If it blows immediately, I'd check the power and ground.
If it is blowing the fuse while operating, I'd try a 30A and see if it holds. At maximum output of 100 watts times 4, the amplifier needs about 31 amps of current at 12.8V. So driving it hard could certainly blow a 25A fuse.
Hope this helps.
Jun 13, 2009 | DHD LCD-9444 Car Audio Amplifier
Blowing fuses
Here are some answers:
1. Make sure your amp does not have a higher amp rating then the fuse, For example, an 18 amp amplifier will blow an 15 amp fuse, so connect it to a 20 amp fuse
2. you have a connection issue, where something is shorting out
3. you are pushing the amp or car to it's limit with how loud you put it, and thus blowing it, fixed by getting a more powerful amp and a better fuse.
4. or there is something very wrong and cannot help you and you would have to bring it into a shop.
Nov 18, 2007 | Car Audio & Video
Car Audio & Video Logo
276 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
