Question about Maytag SAV2555A Top Load Washer
Water leak upon filling at top/cabinet joint
The water leaks between the cabinet and the top at the left side rear area when filling the tub. it seems to be somehow related with the water level selector.
  • Anonymous May 02, 2009
    I have the same problem. I can lift the top of the washer to see the water leaking at the clamp of the intake hose where it hooks onto a black plastic part. I can't raise the top farther than about 3 inches to get to the part. I don't want to force it. Any suggestions? Thank you.
  • nycpccr May 02, 2009
    I have the same problem with water leaking when the washer is filling. I can raise the top far enough to see the water leaking from the intake hose at the back where it clamps onto a black plastic part. I cannot raise the top more than about 3 inches to get to the part. I don't want to force it. Any suggestions on tilting the top back? It's a very old Kelvinator (W841B) and I probably won't be able to get the part. It looks like a hose that can be purchased from an auto part or hardware store. I can only see the top of the hose where the leak is, so I don't know if there is more to it than just a hose. Water is spraying out right at the clamp. The machine is old enough (40+ years) and the hose is original, so it would make sense that the hose is dried and leaking finally. Thank you.
  • Maytag Master
  • 3,361 Answers
Raise the washer top and inspect the water fill tube and the water level air hose.
You will need to set the timer to fill while you are watching for the water leak.
Posted on Feb 23, 2009
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
My kenmore washer molel 110-82873120 is leeking from the top.
Dear R.A.,
If your washer is leaking you should first check the hoses.
  • There are several types of hoses found on a washing machine and the most common are the drain and fill hoses.
  • The fill hoses connect the household supply to the water inlet valve and are normally located at the rear of the washer. Check to make sure that the threaded fittings are tightened securely and that the leak is not caused by the faucet.
  • The drain hose is also located at the rear of the machine and may not be properly installed into the household drain. Verify that the leak is not caused by a restricted household drain that is backing up through the stand pipe.
  • Washers will also have internal hoses that connect the inlet valve to the tub. A defect in this hose would create a leak during the fill cycle.
  • Access the tub inlet by lifting the main top or removing the cabinet and inspect the hoses for signs of abrasion or cracking.
  • Also inspect the other components of the water inlet system such as a siphon break or tub injection assembly for signs of a leak. Check for loose or corroded clamps, and cracked or perforated hoses.
  • Your inlet Valves may also be totally defective and cause the washer to overfill therefore causing a leak over the top.
  • Check for the tub Pressure switch assembly may be defective causing such leak.
  • Your model requires removing the complete cabinet.(front and sides come out as on piece) Here a link to all your machine parts
I think we cover all the possibilities.
Best of Luck,
JP
KENMORE AUTOMATIC WASHER Parts Model 11082873120 Sears PartsDirect
Jul 03, 2015 | Kenmore Washing Machines
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
5 year old wash machine leaks as the tub fills with water out the bottom somewhere. Hot and cold hoses are tight, drain hose is tight. This machine was just moved from one location to another. What could...
your tub seal between the top of the transmission and the wash tub, or the fill tube hose to the load size control may have a hole in it from the lower tub to the control panel on top
Oct 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Leaks while tub is filling.
could be any number of things: water inlet to tub leaking and running down outside tub,tub seal on top of transmission,pump leaking,bad hose washer remove top and front cover,then plug-in and let it start to fill you should be able to see your leak easier that way be careful when plugged-in
Aug 02, 2009 | Amana NAV2335A Top Load Washer
Keeps over filling and water leaking out of side and front
There is a valve mounted on the rear of the cabinet which is supposed to cut off the water flow when the water level reaches a set point. A clear plastic tube will run from the bottom of the tub to this valve. Replace the valve, reconnect the plastic tube. Should solve the problem.
Apr 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Maytag SAV2555A Top Load Washer Logo
252 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
