Question about Roland Vs-2000CD Digital Studio Workstation System
Transpose feature on the Roland RD-600 digital piano
1. I understand that you can transpose a song written in the key of C to any other key by depressing the ''transpose'' button on the piano, and then depressing the key to which you want the song to be transposed. However, if a song is written in a key other than the key of C and it needs to be transposed to another key (i.e., key of A to the key of G), is there a way to use the transpose feature to do this?
2. Is there a way I can download an operating manual for this keyboard?
If you want to play in C and carry the sound of Bb,
1. From C, count down two half-steps to Bb
2. Press and hold the Transpose button and press the key on the keyboard that displays through the window, "-2"
3. To turn off the transpose feature, just press the Transpose button again.
Posted on Apr 13, 2009
Is there a way to program the whole keyboard to play 1 octave lower?
You can use TRANSPOSE/SETTING button.
Each press the TRANSPOSE/SETTING button cycles through the setting screens. If you accidentally pass the screen you want to use,keep pressing the TRANSPOSE/SETTING button untill the screen appears again.
To lower by one octave,set the value to -12
You also can use PIANO SETTING button.
Find the setting in page 07 of PIANO SETTING.
Sep 03, 2015 | Casio CTK810 61 Key Keyboard
I have a Yamaha P-105. It is just over a year old and we have never attempted to transpose anything. Tonight I tried and it won't work. I hold down the DEMO/SONG and METRONOME/RHYTHM button
i would discuss it with the dealer you bought it from. He'll have you go though the commands again just to be sure. At that point he'll ask that it be brrought in for service or will refer you to a service center. If it is over a year old it will be out of warranty, but if you approch him polietly he may try to bend the time period for you.
Dec 03, 2014 | Yamaha P-105 Digital Piano, Black
I have a Roland E-70 Intelligent Synthesizer, buit the manual does not give instructions on how do transposition. I need to transpose the instrument to play a music in a lower key. For example, when I...
section 7 page 89 of the E-70 manual I downloaded from http://www.rolandus.com/support/owners_manuals/?group=2
describes the use of the transpose button.
In short, you set the value for the transpose function in the parameter menu (section 9 in the manual) ranging from -11 to +11 semitones.
In your case I would set the value for the tranpose button in the menu to minus 2 as you want a full note (= 2 semitones) down from C to B-flat and G to F etc.
And you activate or deactivate the transpose function itself by hitting the transpose button. The little red led next to the button shows whether the function is on (led is lit) or off (led is not lit).
Hope this helps
Mar 12, 2012 | Music
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Jul 26, 2011 | Yamaha Music
HI, I have a Roland Juno GI, (5 months old), have not programmed anything into it or changed any settings. However, when I started it today it was flat by 50 cents. I was sure of this by checking a D or G...
It sounds like it is transposed. Look for the transpose function in your user manual. It shifts the keys by half notes either up or down. I would be surprised that factory reset would not clear the transpose setting. First, realize that these keyboards are controlled by a crystal oscillator and they just don't drift enough to shift even one cent worth.
IF the unit is NOT transposed, then the other problem is LIKELY with the pitch bend wheel. Try the action of the wheel and make sure it responds by moving up and down about 50 cents. If it doesn't go both ways, it is possible the mechanism has slipped or been damaged.
Jul 19, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
I have Casio Ctk-496 and I have MIDI-USB wire. It all works, but Transpose button doesn't transpose and casio chord doesn't work with my computer. And all is still working even if I pull out IN wire from...
Casio Chord is internal to the keyboard and doesn't come out on MIDI. Transpose is similar and while the button may send a MIDI transpose type signal out, the notes will not transpose in your computer...
Mar 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
I have a Casio Privia Px330. On a split keyboard how do I alter the right hand tone?
On page E11 of your manual... see the picture with two voices, one for the T and one for R... select them there.
Your manual can be downloaded here: http://support.casio.com/pdf/008/PX330E1A_web.pdf
You probably cannot "change the tone" of the two voices if they are the same voice. You should be able to transpose to different octave however.
Feb 03, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Transpose feature
Here is the ROLAND website. I am afraid that you have to give you e-mail to go further.
http://backstage.rolandus.com/login.php
Dec 17, 2008 | Roland Music
Roland Vs-2000CD Digital Studio Workstation System Logo
853 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
