Question about Elna 8007
My Elna Carina 65 doesn't feed fabric . I've
My Elna Carina 65 doesn't feed fabric . I've cleaned it , and adjusted the tensions. It seems to sew very small stitches. I've had it for about 25 years. It's never done this.
  • Elna Master
  • 1,133 Answers
Is it possible that you've lowered the feed dogs and not raised them again? Is the stitch length dial set to 2.5 and not on a buttonhole blue setting or the Automatic "A" setting?
Posted on Mar 27, 2011
Tension settings for the elna lock t34d
all Sergers are usually set up so that the "normal" thread tension is 5 on all the dials, however you then adjust these slightly to achieve the stitch format you you want. Stitch length (dial on the side) is usually around 2.5. If your machine has differential feed, then start with this on zero.
Overlocks are different to sewing machines, the stitch forms differently depending on the fabric weight and where the blade is cutting so you usually do a little test on scraps and finesse by adjusting the looper thread tensions so the stitch forms evenly on both sides. If its tunnelling, ie pulling the fabric in, then release the two loopers or move the blade to the left to trim closer, or do a little of both.
Mar 18, 2017 | Elna Sewing Machines
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
How do i adjust the tension on elna 2003?
Not quite sure what you are asking. The upper tension is governed by the tension disk. Higher number is tighter, lower number is looser. Usually, the mid-range is a good place to start. Tension is correct when upper and bobbin threads meet in the middle of the fabric.
NOTE--ALWAYS RAISE the presser foot when threading so the thread will seat in the tension disk!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Just FYI:
Why my Elna sewing machine is bad Or dont buy an Elna 2007
Dec 08, 2016 | Elna Sewing Machines
Why won't my Elna SU model 62c feed fabric?
thread looping on the underside is a symptom of no tension on the top thread so you need to look at the top threading path and the tension dial, is it set to 5? and is the thread pulled fully into the tension disc? Also always thread the top thread with the presser foot raised as this opens up the tension discs so the thread can bed in correctly. If you can see the feed dogs rising up and down above the needle plate during their cycle then they should be gripping and moving the fabric forward. Is there presser foot coming down firmly onto the fabric when you release the presser foot bar? This part does have a big spring inside which applies pressure downwards, maybe this is what the mechanic meant was broken. Was he a sewing machine technician? Maybe try to locate an old school Elna technician, start with www.elna.com and go to your country, then search for a local dealer.
May 25, 2014 | Elna Sewing Machines
Machine is skipping stitches.
1. Please fabric -> correct sizes needls. And check the needle clamps. 2. Please fabric -> adjusting tension. And check the tension disc.
Jan 09, 2014 | Elna Sewing Machines
Need to drop the feed dogs on my elna carina sewing maching
The Carina came with a metal plate that you clip over the feed dogs onto the metal plate (rotary hook cover), they don't have the feed dog drop feature.
Sep 06, 2013 | Elna Sewing Machines
What does feed dog lever do on my Elna 6005 Heirloom sewing machine? Do I need to alter it for sewing very thick fabrics/seams?
Feed dog lever should lower the feed dogs, these are the teeth that grip and move the fabric foward and backwards as the needle goes up and down, they are under the needle plate.
Only time you would lower the feed dogs is if you want to do free motion embroidery or darning perhaps.
So no, don't touch for normal seam stitching. If you are sewing very heavy fabric you may want to lessen the pressure on the presser foot a little (if your machine has this adjustment it will be a knob on top of the head above the pressure foot area).
You may find that your machine doesn't really like very thick fabrics. Sewing something like upholstery weight with a domestic machine is pretty ambitious; an industrial strength machine is best bet.
Nov 09, 2011 | Elna Heirloom Edition 6005
Sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Jul 01, 2007 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
431 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
