Question about Sony VAIO VGN-FS980 Notebook
Blank screen when booting up
I am having problem getting my computer to boot up. I get a blank screen after I pick safe mode. My computer is a Sony VGN-NR498D/S
  • june_crase Feb 23, 2009
    nothing works no matter what one I pick when i hit f8 it then goes to blank screen
Why are you trying too boot in SM ?
Posted on Feb 23, 2009
2 Suggested Answers
RescueTechLA
  • 2653 Answers
SOURCE: getting a blank screen
Press F8 when you start the computer. Are you able to boot into "Safe Mode with Command Prompt"?
Let me know and we'll go from there.
ON boot up the screen goes blank ater half a second
if the screen goes blank when the windows boots up ...than it is a driver issue and you should boot in safe mode (press F9 or F12 for boot menu ) ..and while in safe mode you have to reinstall the video card driver cause it is corrupted..You should do that just in case it is getting blank in the moment windows should kick in ..
If it is right from the start than it is a computer issue ..and it is either the Ram memory to blame ..and it is booting up in a loop ..and in this case try to remove it ..and boot with on ram memory at the time and see if one of them is faulty ..or if ti is just one ..remove place back ..and also remove the cmos battery to clear settings and boot again and see what s going on ..It may work and in this case problem solved ..or not and you should try new memory ..
Or the worse case..this can be a CPU failing ..and you will have to change it ..
Jan 29, 2011 | Sony SDM-E76D 17" LCD Monitor
My Sony Vaio VGC LA2 shows green lines at startup and after windows processing screen it goes blank. The problem started when it used to hang-up whilst the screen saver came on and the system freezes...
have you tried booting in safe mode?
as the system is booting repeatedly press F8 until a menu appears where you use the aarow keys to select safe mode by pressing enter.
Jan 24, 2011 | Sony Computers & Internet
Sony vaio ns. my desktop is blank, im unable to use my laptop as i cannot see or open anything.
On the Windows Operating System you can boot up to safe mode by pressing f8 continuesly while booting until you get a menu that lets you go into safe mode. Go into Safe mode then it will give you the option to do a SYSTEM RESTORE. It will bring up a calendar and let you pick a earlier restore point where you didn't have that problem. It will not delete any programs so don't worry about that.
I hope this helps,
cdixon18
The Man Inside the Machine!
May 11, 2009 | Computers & Internet
Sony VGC-LS35E BLANK SCREEN
Do you mean after windows has booted you have a blank screen?
Boot into windows in safe mode (by pressing F8) during the boot up process.
When booted go into device manager and remove any video drivers under display adapters, if it asks to delete the files as well answer yes.
Reboot into normal mode and let windows find the driver for you.
Apr 19, 2009 | Sony Computers & Internet
Getting a blank screen
Feb 23, 2009 | Sony VAIO VGN-FS980 Notebook
I have a Dell GX60 and I changed the display resolution and
So, with The computer, completely turned off, Turn it on, Can't you see the BIOS screen? , or a Dell LOGO?
It is when you see this BIOS or Dell logo Screen that you Need to:
  • PRESS F8
  • Press F8
  • Press F8, again, and again right when your computer turns on.
Then You should be brought to the Window that allows you to boot into SAFE MODE, DO NoT PICK SAFE MODE.
Pick: ------------ENABLE VGA (basically safe mode) Only!.
Once booted, log in and change the resolution to let's say 800x600,
then restart your computer normally.
You should then be able run windows normally, (Without F8 Key) where you can then change the resolution to what you want.
IMPORTANT! Remember this, if you set your display to a resolution that it Does Not
support, and the screen goes blank. DO Not Turn off your computer: ALL YOU DO IS PRESS
the (Esc) ESCAPE Key within 15 Seconds and your monitor's resolution will be set to it's
previous state again.
I Hope This Helps.
Jan 30, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Safe mode boots okay but not in normal boot - no error either
Do you have the original recovery disk? I recommend inserting the recover disk, restart the computer while continually pressing F12. Select boot from CD, press any key when asked, and you would want to do a "repair". That should fix your problem.
Jan 12, 2009 | IBM ThinkPad 600X Notebook
Boots but to a blank screen just the pointer remains
Have you tried safe mode? You can access it by hitting F8 while the computer is booting up (I tend to press it at 1 second intervals, much faster and the computer gets annoyed :P) You'll get a menu that will let you pick safe mode.
If you can get at the desktop in safe mode then i would suggest shutting off all your start up programs (the list can be accessed by going to the start menu, selecting run, typing in "msconfig" and pressing enter). After those are shut off try rebooting back into normal mode and see if that works. If it does, then you know that a program starting up with the computer is causing the problem and just need to be singled out and removed.
Good luck :)
Dec 17, 2008 | Toshiba Satellite A105 Notebook
Its on but just has a blank screen ??
First see if it will boot in the Safe Mode, pressing F8 when the computer starts up. Choose Safe Mode in the boot option. If it will boot in the safe mode. Restart the computer and press F8 again and select Start in the last known configuration. Hopefully
this will fix the problem. If not and you are running XP Pro, boot in the safe mode and do a restore. you get there by clicking Start, Programs, Accessories, System Tools, System Restore, choose a date that the computer was working and click Restore.
BPCS
Dec 21, 2007 | Acer Aspire 5630 Notebook
Sony Vaio VGN SZ330P
Try "Safe Mode " by pressing F5 or F8 while booting, if you dont have hardware problem on hard disk or somewhere safe mode with take you to system without loading many drivers and startup programs.
Dec 06, 2007 | Computers & Internet
Sony VAIO VGN-FS980 Notebook Logo
215 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
