Question about Kenmore Refrigerators
Kenmore elite side by side: hot divider
Kenmore elite side by side: The front of the middle piece separating the freezer and fridge becomes extremely hot to the touch. Cools down later and then becomes hot again.
  • Anonymous Mar 29, 2014
    fridge cooling but inside door very hot to the touch, divider wall in front between freezer and fridge door. ice make not making ice also
  • Kenmore Master
  • 3,361 Answers
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Posted on Feb 23, 2009
Squeaky, chirping sound & exterior of fridge on veritical middle panel and freezer side are hot
I think you should try the following:
1. turn off the power.
2. clean/vacuum the lint under and behind the fridge.
3. after a few hours, power on.
If this does not work, you will have to call a repairer unless it is under warranty.
good luck
Mar 15, 2014 | LG LSC26905TT Side by Side Refrigerator
Kenmore elite model#5059903 the divider between the freezer and fridge gets extremely hot.
Refridgerators have coils than run thru then body of the fridge. They are there to reduce moisture and condensation. It is normal for tham to get warm and sometimes they do get hot it happens when the coil is too close to the body. Normally it only happens periodically. If it is so hot it burns or if it stays hot and dont stop than you have two options. #1 move contents of fridge to another location (back up fridge) and unplug for 24 hrs leave doors slightly open and have some towels near bottom there will be a little bit of water. Plug back in if this does not work. Contact the manufacturer and let them know. There may be a defect in the design.
Jun 05, 2011 | Kenmore Side by Side Refrigerator
Kenmore elite side by side w/ middle divider super hot
absolutely not
that middle peice should be hot to the touch
this is the mullion heater or yoda loop in the old days
this is what controls moisture from entering the unit
when you open the dooor
mine has been running for 7 years no worries
Oct 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore elite freezer/fridge hot to the touch on the front.
I recommending unplugging the fridge, taking off the back panel, and at looking in there. I was having the same symptoms, overheating panel between the doors on our side by side. Ends up that a mouse was stuck in the fan and stalled it out. Fortunately (at least so far), once I removed the mouse and plugged back in, the fan started back up.
Jun 25, 2009 | Kenmore 63893 Stainless Steel Top Freezer...
Possible fire hazard
we have same one ours gets warm but not hot enough to discolor you better call for service immediatly definate fire danger good luck
Mar 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Mar 11, 2009 | Refrigerators
Panel between fridge and freezer extremely hot
this is happening because company used pipes inside refrigerator body, as you mentioned now its heating more than normal,. need some technician to check if there any blockage etc. otherwise less heating of body is normal.
Nov 30, 2017 | Kenmore 44103 Side by Side Refrigerator
Samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
898 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
