Question about Aiwa Televison & Video
Need coax adapter cant find it any where - Aiwa Televison & Video
  • 49 Answers
Try radio shack .
Posted on Feb 23, 2009
Female coax connector broke on vizio smart t.v.can i buy an adapter or reroute out of cable box to t.v.
If the cable box has an HDMI or video output, use one of them to connect to the TV instead. The female coax connector is not easily repaired and you can't reroute or adapt anything to fix it. You will need to replace the TV main board if the HDMI/video connection is not an option.
May 05, 2017 | Vizio Televison & Video
Actiontec ecb 2500c
Having the same problem. Adapter and MoCA functioned perfectly for one year for Tivo on Xfinity, then one day stopped. Modem/router work fine when I remove the adapter and set them up alone. Bought a replacement adapter, and when it's all plugged in nothing happens except the power light blinks.
Dec 15, 2013 | Actiontec Ethernet to Coax MoCA Network...
Cannot find where to connect aerial lead into tv
If set has a coax or cable fitting and antenna lead is flat wire you need a adapter---flat wire is usually 300 ohms and the coax is 75 ohms, the adapter in that case will allow you to attach the flat wire to screws on it and then slide the other end onto the cable fitting.
Dec 22, 2012 | Televison & Video
I have recently purchased an atari 2600 that came with no rf cable. I understand that using the female phono to male f adapter will work to hook it up, but this leaves me needing to buy the phono cord...
Yes, I know this works because I have done it. I believe both types of cable are the same impedence but different ends so any combination should work. Cheers.
May 14, 2011 | Atari 2600 Console
How do i connect areil lead to outside ariel
you don't say what kind of wire you are using. If using coax, just screw the coax connector onto the back of the set, the other end should fasten to the connector on your outside antenna, If you are using 300 ohm wire, then you need to purchase an adapter that goes from 300 ohm to coax connector (these are called balun connectors) you can get one at radio shack..
Mar 16, 2011 | Televison & Video
I cant find were to plug in the aux wires.. the red, yellow, and white wires. from my games.
If there is not a front panel the opens and there's not any on the back that say input then you need to buy an a/v to coax adapter.Here is a link for the adapter.
http://salestores.com/rcacrf90.html
hope this helps.
Apr 04, 2010 | Zenith B19A02D 19" TV
BNC video output on SAMSUNG SHR-1041K
You are going to need a RF-Converter.Most come with a 65db or more built in amp.This is your best bet if you got an existing RF network.The other method is a video splitter and run a separate video feed to each tv's video input.I just use a BNC "T" on mine
Mar 28, 2017 | Samsung 4 Channel Dvr
Trying to hook up "back-up camera" which only has a coax output jack. Can I hook it directly into "ANT" jack or do I have to go through a demodulator and reduce to an RCA and then plug into V1 jack?
I would be interested to know the model number of the camera. "Coax" jacks are usually only used for tuners. It is more possible that it is a BNC connection. If it truly is coax than they may have used the coax jack because an RCA style plug would come unplugged too easily while driving.
Just get an F (male or female depending on the connection) to RCA (female) adapter and an RCA cable and plug it into any composite (yellow) video input.
If it is BNC than get a BNC to RCA adapter.
http://www.cablesnmor.com/bnc-rca-adapter.html
Take the part into Radio Shack and they will have the right adapter.
Nov 25, 2009 | Sylvania 6615LFP 15 in. EDTV-Ready LCD...
No coax cable in my tv?
some itc22 do not have a tuner, DOes the front say hd monitor?
Aug 21, 2009 | RCA HD52W59 HDTV Projection Television
Reception/ jacks on the back of a SHARP L32 - X200 Cinema select
go to VCR, OR DVD player. Use channel selection there.
Dec 07, 2008 | Sharp 32L-X2000 32" TV
Televison & Video Logo
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
