Question about Capcom Demon's Crest for Super Nintendo
Crest Audio Console Fader Distortion
At certain points in my fader position in a channel the channel will distort. The Pre Amp is not being overloaded as is no other part of the board. What part of the fader is going bad or could it be from residue on the guide rod?
Change your fader. Because your fader had some problem like funges or corbun pealed up. so try to change.
sampath india
Posted on Apr 27, 2009
Are the fader and balance on my car stereo supposed to work after a new stereo amp has been installed ?
if everything was correctly installed then yes, but depending on what was used, the installer may have opted for a custom configuration. however, the fader and balance really should work.
Jan 07, 2014 | Car Audio & Video
Tip
How to Set up Auxiliaries on a Mixer.
Here are some tips to set up the auxiliaries properly on your mixer:
  • Step1:
Your auxiliaries allow you to send the signal from a channel strip to somewhere else while maintaining the signal on the channel strip. For instance, you can use auxiliaries for monitor mixes for performers in a live environment. You can also use auxiliaries for external effects processors or a number of different situations.
  • Step2:
Set the auxiliaries to pre-fader to allow you to change the level for the auxiliary with the auxiliary knob but not with the channel fader. Most mixers have a "Pre" button that allows you to enable pre-fader mode. If you don't have the button pressed, your auxiliaries are in post-fader mode, which means your channel fader will affect the signal level of the auxiliary output. For monitor mixes, you usually want to use pre-fader so you can control monitor mixes independently from the front of house mix. Some effects processors will be better to run post-fader, though, so don't always rely on pre-fader.
  • Step3:
Send out your auxiliary sends. On the back of your board, you there are the auxiliary outputs. For a monitor mix, you will use these outputs to connect to the inputs of the monitors. When using an effects processor, you will use the auxiliary output to connect to the input of the effects processor.
  • Step4:
Plug in a return if necessary. If you are just doing monitors, you do not need returns to the mixer. When using effects processors though, you need a way to get your effected signal back to your mixer. Take the output of the effects processor and connect that to the return input on the back of the mixer. Now you will have to adjust the return section on your channel strip to get the desired signal.
  • Step5:
Use the auxiliary knob to set the desired level. Once you know if you are running pre- or post-fader, and you have your inputs and outputs all correct, you can start sending signal to your auxiliary output. Turn up the auxiliary knob until either your monitors are set correctly or until you have the desired amount of signal going to your effects processor or other outboard equipment.
on Aug 07, 2008 | Yamaha Mg102c Stereo Mixer
Allen & heath xone 42 fader problem channel 1
Carbon track on fader 1 is open because of wear or just broken, if you are getting sound then the ground carbon track is out but certainly the problem lies in the pot.
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
I am unable to send a signal via aux 6 from a channel to ONLY the K sub. The only way I get signal is if I raise the channel fader but then the signal goes to the house L/R mains as well. How do I send a...
It appears that AUX6 is default factory strapped as POST FADER. If you want to change that you will have to disconnect jumper L to A for all channels you want the AUX to be pre-fader and instead connect K to S for the option jumpers. I don't know if this requires soldering or whether they are push on jumpers. These should be available in the back cover. In ADDITION you will have to run the switched pre/post fader switch in the PRE position which will make ALL AUX's that are strapped this way PRE FADER.
Jul 09, 2011 | Allen & Heath Mix Wizard Wz3 16:2...
I have an Allen & Heath 16:2 DX with two fuzzy preamps. Tried contact cleaner with no improvement. Sounds like a preamp problem - lower volume than the rest of the channels with distortion as more...
NEVER, NEVER put contact cleaner into the faders!!! It removes the lube and the faders will be damaged in short order. Try using CRC226 available at Home Depot in the electrical dept. Use ONLY the CRC226 as there are other CRC products that are not applicable. Squirt some in the center of the slots... not too much and work the sliders... if they improve try a little more... If they are still bad, replace the sliders... it is a MISERABLE job involing removing mass number of knobs, screws, etc... and then getting/finding the replacement fader control. Usually I get them from Digikey.com or Mouser.com and sometimes the actuator tab has to be trimmed to length with tin snips so knob will be at right height. The fader must have the same resistance and TAPER as the original as well as mounting tabs.
Jul 05, 2011 | Allen & Heath Mix Wizard Wz3 16:2...
Hi - I have had no problems programming or using the unit - its ok in its own way - the behringer LC 2412 ontroller. The problem comes in the form of what on old desks I would have called "pre...
The LED cans are not easily dimmable to very low levels. The signals sent are all digital. It is POSSIBLE that the A channel fader doesn't go low enough electrically within the console and the conversion to the control stream of data is NOT commanding a low enough level. LED's are HARD to dim below a certain point and what would happen is that in the multiple strings of each color, some stings would go completely out before others... SO it is possible they have a minimum SET in the PAR can that is the lowest level that can be done without dropping off some of the internal groups and making a mess of the color. There would be NO solution available to you in this case.
Jul 05, 2011 | Behringer Eurolight Lc2412 24channel...
Distortion with HK AVR 144
This sounds like the amplifer is playing up. If the distortion is on more than one channel, you are looking at a faulty part common to both channels. If on one channel only, perhaps something in the pre-amp or power amp sections. Have a look inside, you might find a burnt resistor, which would cause it.
Dec 21, 2009 | Audio Players & Recorders
The main bus on my behringer 2222 mixer has gone. nothing patched to the main bus comes up on the main vu meter, and only a feint distorted noise comes out of the headhones when the main bus is turned up...
please make all your fader down-all your rotary control at middle(12 oclock position)------all your pressed pushbuttons in up position--disconnect all inputs cables----use good new cables for outputs---bring a good mic and connect it to any channel and raise its fader up and main mix faders up and check if the problem solved check your cables and your pressed button if not better to contact a good service center.
Aug 17, 2008 | Audio Players & Recorders
Distortion sound
turn down the gain at the mic pre, first plug in the mic then put the channel fader at optimum level, the 0 mark, then use the mic gain adjustment at the mic pre to set the level on the channel/ input meter, if recording using a digital platform keep the level as high as possible without going into red at all on the channel/ input meter, use the master fader to adjust listening volume and use the channel fader to make fine adjustments if needed but the point is to primarily use the mic gain knob to adjust the input level. If you are recording a loud instrument or cabinet with it then you may want to use the pad on the mic or the pad on the console/ mixer if after going through the above steps the level at input is still too hot, should be a switch on the mic or console wich says pad, if the mic has one then use the one on the mic instead of the one on console.
Jul 07, 2008 | Sennheiser ew 135-p G2 Professional...
Capcom Demon's Crest for Super Nintendo  Logo
89 people viewed this question
Top Capcom Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Piyal Perera
Piyal Perera
Person On the...
Level 1 Expert
Are you a Capcom Video Game Console and Game Expert? Answer questions, earn points and help others
