Question about Dryers
Connection We just got a free washer and Dryer and the dryer plug is 3 prong. I went to home depot and bought a 4 prong plug(our house has a 4 prong connection in the wall) and the dryer has 3 wire connections in the back and 1 green wire grounded. The 4 plug wire I bought has the 3 wires and a green wire for the ground. Do I disconnect the ground from the dryer or just put the ground from the new plug and the 1 from the dryer and ground them together?
  • 70 Answers
The green wire will attach to the dryer cabinet. The white wire will attach to the middle and the other two(red& black) will attach to the outside of the terminal block.
Good Luck!!
Posted on Feb 24, 2009
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Start button not working
nope 4 prong is for mobile homes and 3 prong is for house. Maybe you wired the cord wrong.
Jan 05, 2014 | GE DPSE810EGWT Electric Dryer
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 | Dryers
What kind of a plug in is needed for a dryer. My dryer has 4 prongs and my house outlet only has 3 prongs. I bought this house three weeks ago. I bought my washer and dryer when the gov;t. was giving...
Hi fran707al
If you already have a dryer receptical/plug then look at it closely and you can purchase a receptical/plug at a Home Depot type store or your local hardware store.
I will send you to a webpage that will show you how to wire a 3 wire or 4 wire dryer Circuit/Dryer
Free answer...Please take time to rate me
Hunter
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
May 26, 2011 | GE Dryers
BOUGHT A USED STACKABLE FRIDGIDAIRE AND NEED THE PLUG FOR IT, WHERE CAN I GET IT? WHERES THE MODEL NUMBER ITS A HEAVY DUTY CROWN SERIES
The Model number could be on the top of the machine or around the dryer door or by the washer lid. if your looking for a 220/240 volt 3 prong cord you should be able to get one at lows or home depot
Jan 09, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
My 220 plug is a three prong and the used dryer I bought has four prongs. Is there some type of adaptor I can buy to connect the two plugs such as what used for adapting a 110 line that has two different...
Hello Doris, You really don't want to get an adpater for this, (even if you could find one - they're not at all common) since the thickness of adding in an adapter would make the dryer stick out further from the wall, etc.
What you need to do is to get a new "pigtail" for the dryer that has the three (3) prong plug that matches your 220 Volt-AC wall outlet. These are available at most Home Depot, Lowes, Sears, or at any appliance or Hardware store. They don't cost all that much and will provide you with the correct plug and cord set for your house's electric dryer outlet.
The four (4) prong cord & plug has a separate ground wire in them, while the standard thre (3) prong plug uses the netural as the ground, or has a separate green wire running from the dryer cabinet to either a grounding screw on the wal plate, or to a ground ******** a water pipe (typically found in older homes)
Just be sure to unplug the dryer before changing the cordset out for the 3 prong one. Make sure the power is also off at the breaker panel too. Now at the rear of the dryer there is a small access panel where the cordset goes into the dryer. Remove that panle and you'll see three (3) connections on the panel along with a Green Grounding connection.
The connectors that get the power are the outside connectors, these are "HOT" and get 120 V-AC each (120 x 2 = 240 Volts AC) while the connector in the middle is the NEUTRAL connection point.
The wiring is straightforward and there should be a simple wiring diagram either on the access panel or the connection points should be labeled for each of the wiring fasteners (screws or nuts)
Just be sure to get the fasteners tight, and the new 3 prong cordset you buy should be long enough to reach from the dryer (when it's pulled away from the wall) to the house outlet. Typically they come in either a 3-4 foot length or the longer ones are 5-6 feet long. If in doubt, get the longer cordset. You can also check the wrapper of the new cordset, as they provide a simple wiring diagram also, to help you install it correctly.
http://z.about.com/d/electrical/1/0/r/0/-/-/DryerElectricalConnection.jpg
Just be sure to add the included strain relief, as instructed, onto the cordset and put the access panel back on when you're done and you'll be all set to use that "new" used dryer!
I hope you find this Very Helpful and best regards!
Nov 16, 2009 | Maytag PYE2300AY Electric Dryer
Brand new dryer threw braker twice, then no heat and timer stopped working. Electrician tightened connections on wires to dryer settings dial, had heat for one load, then same as before. Replacement dryer...
might want to check your dryer outlet. If the terminals are loose in there it could cause you problems. If your dryer plug is a 4 prong you might be loosing one of your 220v legs due to a short . As the dryer runs the wires and connections will heat up and expand , if there is a faulty wire or connection then it may loose connection after a load. could be quite dangerous and a very possible fire risk so i would check it out ASAP . if the outlet is old they sell for about $20 at you local home depot or lowes home improvement. for a 3 prong plug you need to hook up the black and white wires on the brass screws and the copper ground wire to the green screw. in a 4 prong application you hook up the black and red wires to the brass screws, the whit wire t the silver screw and the copper ground wire to the green screw .
If your new dryer is supposed to be a 4 prong plug and you have it with a 3 prong cord then you will run in to issues . The difference being a 4 prong electric dryer is a dual voltage unit where it needs both 220v and 115v to operate correctly, where a 3 prong dryer only has 220v and the earth ground. if your not familiar or comfortable with electricity please call a qualified electrician to come hand handle the work. if not done correctly it can cause fires or possible electrocution
Oct 30, 2009 | Amana NED5500TQ Electric Dryer
New house requires 4 prong plug for dryer...mine has 3...bought new cord...How to wire it?
The old three prong, the vertical prong is neutral (white wire), the two slanted are 220 volts. The new plug, the extra prong is ground (bare wire). Shut off the outlet at the breaker panel, and remove the outlet to examine the wiring to it. It should be as above--the 220 volt wires are red and black or black and black. The ground wire is bare or green insulated. Inside the dryer case, tie the green and white wires to the dryer case, and tie the two outside wires where they went with the old cord. Check with an electrician if you are unsure about this.
Jul 16, 2009 | Dryers
Whirlpool dryer
no go to a home store like lowe's home depot or others ad buy a switch kit
Feb 21, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
148 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
