Question about Compaq Presario Notebook Notebook
Battery not holding charge w/adaptor plugged in
Battery not holding charge with adaptor -- must wiggle adaptor to power up/maintain power on laptop
    President:
  • 2,653 Answers
Your dc jack needs to be replaced. When you wiggle it you make it worse and worse, eventually it will just stop working completely or worse you could damage your motherboard.
Should cost $80-100, if you're paying more than that you're getting ripped off. Either find a local repair shop that will do it or someone on craigslist. The whole motherboard doesn't need to be replaced so if they say that then I would take my business elsewhere. Also make sure they order the jack or have the jack in stock BEFORE you leave your computer with them. Not every shop has them in stock, your computer will just sit there waiting when you could be using it in the meantime.
Let me know if you have any other questions and please don't forget to rate my solution.
Thanks!
Posted on Feb 23, 2009
My dell latop wont power on but the charger is working. What should i do?
How do you know it is working? Do you have a volt meter for dc, what reading do you get? It should be near the spec on the adapter. I have had several fail at the computer plug connection. A little wiggle may confirm. For emergency I taped it with a splint.
Any chance you can swap adaptor and or battery with a friend to verify? If your battery is charged, it should boot. My bet is the battery is dead because the adaptor is not working properly.
Mar 28, 2015 | Dell Computers & Internet
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
My dell lattitude 2110 isn't charging while plugged in
It is unfortunate that the computer is not being charged. You may want to try following the below steps which might help:
    (1)Try using a known good AC Adaptor and check if the same issue happens.
    (2)Try wiggling the AC Adaptor cord to see if that makes a difference.
    (3)Check if the AC Adaptor is getting detected (Like a 60W or 90W) in BIOS (F2 at startup).
    (4)Hover the mouse over the Battery on the status bar and see if there is any error message like Not connected or Plugged in not charging, etc appears.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 30, 2014 | Dell Latitude 2110 Notebook
Our dell inspirion 1525 keeps switching itself off when it is plugged into the mains electric. Also the battery does not hold it's charge. What could be the cause ? Thanks
Without looking at it I'd guess at it being the DC power jack (where you plug in the power adaptor). These are prone to wear and tear and are easily damaged. When your laptop is plugged in and is turned on, please 'wiggle' the power jack and see if your machine powers down and/or the charging light comes on. If any of the above happens, then it's your DC jack. These can be replaced.
Zahc
Jan 26, 2011 | Dell Inspiron 1525 Notebook
Acer battery no charge/plugged in "battery is criticically low"
This is a tricky issue, it's either a problem related to the battery or the adaptor.
Try removing the battery and just plug in the adaptor and see if the computer will boot. If it does then there's a problem with the battery and you just need to replace it, if it doesn't then there's a few other things it could be.
The two most likely options is that the adaptor is bad, or the AC port on the computer has become loose. Most of the computers I've repaired that had these symptoms was that the AC port was bad if the battery wasn't. The best way to test this is to plug in the adaptor and just see if it wiggles around a lot, if it's loose then it might not be connecting to the board correctly and will need to be soldered bad on. If it's not loose then the adaptor might be bad, you can test another adaptor on your laptop or that adaptor on someone else's but be carefull, I can't stress this enough, if you're going to switch adaptors you have to make sure that the voltage IS EXACTLY THE SAME and has the same amps, if the voltage is off you can damage the computer, if the amps is off you can damage the adaptor.
If by some fluke it doesn't seem to be the battery, and you tested the adaptor and the AC port doesn't feel loose, then the charging circuit in the laptop might be shot, in which case you'll need a new motherboard.
I think that covers everything, sorry for the wall of text
Mar 01, 2010 | Acer (56.04200.H22) (5604200H22) 200-Watt...
HP Pavilion ze2000 Laptop won't turn on
Have you tried removing the battery and seeing if the laptop will then run?
Jan 18, 2010 | HP Pavilion ze2000 Notebook
My Gateway 1450 will not power up. For the last 2 weeks that battery light has been red (battery need recharging). i had the unit turned off with no ac power to it all weekend and not it will not power up....
The motherboard battery is just a little round battery that you can buy at almost any retailer in most pcs. The model number to the battery is usually a CR 2032. This battery does not receive any power from your power supply. Have you noticed your PC loosing time over the last few months? This is usually a good indication that the motherboard battery is dying. The lights that you refer to though should only partain to the rechargable battery of the notebook. During the past two weeks while the red light was on, was the AC adaptor plugged in to the laptop and plugged into an AC source? If your AC adaptor has been plugged in and is not charging the notebook battery then there could be one or both of the following problems: your notebook battery could be bad or your AC adaptor could be bad. Something you may or may not know is that it is not good to keep the AC adaptor plugged in all the time. This causes the notebook battery not to fully discharge after being charged. Over a long period of time, the battery will not even charge anymore. My suggestion is that if you know someone with a similar AC adaptor to yours, borrow it to see if it charges your battery. If the battery doesn't charge then you know to replace. However, I am almost certain that you problem is the battery. Sometime older laptops like the one I have has a reset button on the underside. If yours has one try removing the battery and leave it out. Then plug in the power and press and hold the reset button for 10 to 20 seconds. If no reset button is on yours then do the same process with the battery removed and power adding, but hold the power button instead.
Dec 07, 2009 | Gateway Solo 1450 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Power
Hello..do you get any life at all with your old adaptor ?....maybe it can be the power connection in your computer that are faulty....try carefully to hold it steady and power up..if so contact your local serviceshop...don't buy a new battery..if so...please tell me how it went...Ron
Mar 07, 2008 | Compaq Presario M2000 Notebook
Battery will not charge
The three likeliest candidates are battery, A/C adaptor and laptop power socket. Battery ? Batteries typically last between 1.5 to 4 years, depending on design and use. They are not safely repairable by users or most computer shops despite what you may read. If you remove the battery from the laptop and can run just off the A/C adaptor then the battery is probably the cause. The next test would be to use the battery in another laptop to see if the same problem occurs there. If it does then the battery is defective and needs to be replaced. If the battery does work then it?s likely the charging circuitry in the laptop itself is defective. A/C adaptor - Even though the green LED on the adaptor is on it can still be the cause of your problem. Inspect the cord, especially the jack that plugs into the laptop. The jack typically takes a lot of abuse and it?s common for the cord to be damaged at the base of the laptop jack itself. Often the damage isn?t visible; however, wiggling the wire at the base of the jack can cause the laptop charging LED to come on and off. The only way to truly test the adaptor is to measure the voltage coming out of the jack under a load. The last part is very important; simply measuring the voltage with a meter does not accurately test the adaptor. An easier alternative if you have the option is plugging a working adaptor into your laptop. Laptop power socket - Most times when the power socket in the laptop goes it?s due to a broken solder joint or a broken socket. Inserting the A/C adaptor jack in the socket and wiggling it back and forth can often cause the charging LED on the laptop to turn on and off. If that happens then the socket or the board it connects to needs to be replaced. That requires a major disassembly and is usually beyond the typical user. Let us know if you have any more questions and please don?t forget to rate this posting.
Mar 10, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
