Question about HP vs15 15"LCD Flat Panel Monitor
The video is inverted i.e. up-side down. i hp vs
The video is inverted i.e. up-side down. i hp vs 15 flat monitor
  • ashish2628 Feb 24, 2009
    Yes problem is solved with this tip.
    Your display is rotated. Many display drivers have "hot-keys" that allow you to rotate the display.
    Open up display properties.
    Click through the tabs to find the rotation option.
    (On my system, the rotation option is on a sub menu on an extra tab under advanced settings.)
    Set the rotation back to normal.
    thanks
  • Thomas F. Schneider May 11, 2010
    Below information  taken from another site: Works?
    Chas
    President:
  • 2,692 Answers
Fix Ya?
Posted on Feb 24, 2009
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
My hp pavilion f50 15in monitor is dark and i can barely see anything on it
Morelikely to be backlight inverter board problem, or worst case will be the CCFL assemblies, this is vey old 15" LCD monitor, not sure if it is even worth to put money into it.
You will have to open it up and check the 12vdc feeding the inverter board and also check the surface monuted fuse on the inverter board.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 01, 2010 | HP Pavilion F50 17" Flat Panel LCD Monitor
I want to connect my playstation 3 to my hp vs15. But after doing a little bit of research i am asked to change my display mode in order to get video from my playstation 3. hence my question is how do...
You change the video resolution at the video source, in this case, your PS3, not at the monitor. VS 15 has 1024 x 768 60Hz Maximum Resolution, so your PS3 cannot be higher.
You need to google 'how to change PS3 video resolution' If the PS3 resolution is set to high, the VS15 will display Out of range/format/video not support.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
May 20, 2010 | HP vs15 15"LCD Flat Panel Monitor
Power light on flashing but no screen
Hello.
There is either a problem with your monitor, VGA cable or PC's video connector. Try another PC or another monitor to narrow down your problem.
If another monitor works, swap the VGA cable on your old monitor.
If another monitor doesn't work, your video connector is faulty.
Hope this helps.
May 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Turns on but very dim
This is a 15 inch LCD. and the inverters of these units go south often.
If the unit does not flicker and you do not have a lose of power, it will be the inverter.
Oct 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor changing colors hpvs 15
Try the monitor with a different computer. If it work, then the problem is the other PC, if it does not work, then your monitor is failing.
good luck
Dec 13, 2008 | HP vs15 15"LCD Flat Panel Monitor
Inverter problem
1800652667 as soon as hurricane Ike gets done with Houston, Texas. Or www.hp.com/go/support
Jul 21, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp monitor black screen
Check for the updated drivers as well as your video card, if you have an internal video card and have tested it (your computer) on another monitor it is more than likely the inverter in the monitor the coils (on the mainboard) need to be resoldered more than likely.
Check the backlight as well
Jun 24, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp monitor
Sounds like the video card, but could be the ccfl inverter starting to go bad or a ccfl lamp going bad.
srich
May 27, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion vf51
It is the inverter board that is causing the screen to be feint. But is was the video resoloution being set too high that made it give the "out of range" message.
It's not easy to get anywhere to repair LCD monitors, and the prices could be well out of scope to bother with the repair.
Having said that, you can now call a few TV repair centres close to you and ask for a quote based on repairing the inverter circuit.
Hope that helps =)
Aug 17, 2006 | HP Pavilion VF51 15 in. Flat Panel LCD...
HP vs15 15"LCD Flat Panel Monitor Logo
100 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
