Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Whirlpool washer my whirlpool duet front load washer keeps coming up with Fdl and F 11
  • 54 Answers
F/11
Serial Communication Error
Communication between the Central Control Unit (CCU)
and the Motor Control Unit (MCU) cannot be sent correctly.
Check Wire Harness connectors to the MCU, the motor, and-
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
F/dL
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked.
It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch-
Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Posted on Feb 23, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
I have an F11 code on my kenmore front load washing machine
After years of suffering from random F11 that became a permanent F11, I did the repair as in the video and all is good for 2 years. No more F11. About one load a day (we have kids!)
Aug 22, 2014 | Kenmore HE2 Plus Front Load Washer
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer keeps flashing f 11 and wont tumble
STOP the insanity....that's what you're saying if you encounter the F11 and/or fDL error codes on your washer. If you're not there yet, you will be soon....
The dreaded F11 and/or fDL codes - been there done ALL that!! Our Whirlpool DUET washer is just over 5 years. We experienced our first F11 code 6 months ago (warranty just expired what else is new?). When it first happened, I thought nothing of it - hit the cancel button and the machine reset itself. Then it happened again and again and again. Each time it happened it was more challenging to reset it. I searched for the fix on line - I should have done my research before we purchased the washer.
I was able to determine the error was stemming from the CCU board. Order a new one at over $300.00 and have the same thing happen again - I don't think so. We tried EVERYTHING suggested on multiple websites.....unplugging the washer, hitting the right upper side, checking wires, wiggling the wires, wedging things to improve contacts, soldering, re-soldering, Vaseline, changed relays....anything and everything was a temporary fix. Contact Whirlpool directly? Tried that too, they apparently don't recognize there is an issue with F11 fDL errors, "not a commonly called in concern". Really?? We started searching washers to purchase....I couldn't bare spending $$$ for another washer, but we are a busy active family with 4 kids - what are our options? Then one night after searching the websites for one last desperate attempt at salvaging our washer, I followed through on a link:
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2
email: selling.surplus@gmail.com
Now, I'm the biggest sceptic in the world and the most frugal consumer - really I am. I am posting my testament to this service because I've been there - frustrated, disappointed, angry. I am so pleased with the service Ed provided - from answering all my questions, to the superb job he did on the CCU. You can review all the comments posted by all his other pleased customers on eBay. I had to stand by my washer for the first 6 loads - just in case the beep beep beeps started. To my astonishment, amazement, and surprise - it never happened!! In my opinion, this is the only true fix for your F11/Fdl error!!
I never imagined in my wildest dreams ever telling anyone how happy I am to be doing my laundry again, but I really am!!
May 13, 2010 | Kenmore Elite 45986 Front Load Washer
NEW CCU for Whirlpool Washer
I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlppool front loading washer won't start, code FdL, door can be opened
"Fdl" is a door latch FAILURE error code. What the error is telling you is that something is malfunctioning with the electronic door latch and/or interconnecting wire or Central Control Unit. It is recommended that you check the wiring harness connected to the door latch or, replace the door latch. The following link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you have any questions or concerns please post back and let me know. I hope this helps you.
Aug 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fdl Code on whirlpool front load washer
remove bottom panel reach up to bottom of door lock there is a small tab pull it down door will come open..if after opening you finda lot of water still in machine suspect pump plugged worse case bad control bd
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
194 people viewed this question
Dan Webster
Dan Webster
Sal De
