Question about Panasonic DMR-ES35VS
Panasonic DMR-ES35V Stuck in "Self check failed"
It asked for a different disc and would go to self test, I loaded a different disc, but now all I get is "Self Check Failed" and instructs me to go the the Service Manual, which I don't have.
4 Suggested Answers
SOURCE: IS MY DVD COMBO REGION FREE
If my combo is region free it does not play region 2
Posted on Feb 07, 2008
  • 3 Answers
SOURCE: dmr e85 will not start up
I have discovered my E85 to have an inadequate power supply. I took the lid off, and used an ancient computer power supply to power the HDD. Since then I have not had a problem with it cutting out dead and self checking on startup whenever I tried to hi-speed access (including dubbing, finalizing, viewing Navigator etc on the DVD.) It does not have enough power to supply every component during peak actions, and just cuts itself out. But not now!
Posted on Feb 25, 2008
SOURCE: Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Posted on Apr 02, 2008
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
My panasonic dmr ez28 keeps coming up with 'self check did not complete' 1) press OK or 2) Press power to restart. I have tried both but the unit then freezes. Can anyone suggest what next?
The Self Check procedure is like the POST on a computer: upon starting the processor makes a simple test of all the hardware components. If it fails then the defect is very important : a critical part situated on the mainboard has failed and it stops the loading of the firmware . Since all parts are glued then the mainboard will have to be replaced. This will be so expensive that it's going to be cheaper to just buy a new recorder.
Dec 02, 2010 | Panasonic DMR-EZ28K DVD Recorder
Self checking
I have had a Panasonic DMR-E85 with this exact same problem you are describing. As I bought a Freeview Dual-tuner PVR I just bought a second-hand DMR-E55 as I liked the Panasonic interface. Two months down the line it is now exhibiting the exact same problems, except now as well as the continual self-check rebooting, it's also refusing to eject the disk. Booo. Time for me to buy a new DVD recorder again, and this time certainly not Panasonic... :(
Dec 04, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
Nov 20, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR E65 cycling in self test on start up
Check the IC in the primairy power supply,common fault.
Jul 22, 2009 | Panasonic DMR-E65 DVD Recorder
Stuck on self check failed
i tried changing drives and then i put in a different dvd.
that worked.
Feb 11, 2009 | Panasonic DMR-ES35VS
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
Mar 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Dvd model DMR-E55
Hi
IC001 STRG6353 on power board may be faulty, mentioned also in several other threads.
Available from various suppliers.
Capital98
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-ES35VS Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
