Home Theater Systems
Problem for Home Theater Systems
Generic problem for all Home Theater Systems
I have an LG plasma TV.The only audio out...
By mpmurphy1 on Feb 23, 2009
I have an LG plasma TV.The only audio out is by optical toslink. I bought an LG home cinema system thinking I would be able to get analog audio out via a scart adapter but nothing doing.
This is so my partially deaf partner can listen on headphones whilst the rest of us listen in normally at a reasonable level. I thought I would get an optical splitter to feed the cinema system and also her ear phones. Trouble is I cannot find a digital to analog converter to supply the earphones. Any advice would be welcome.
Clarification Request
Posted by dscrog on Feb 27, 2009
if you can tell me the model numbers of the Plasma, Cinema system and headphones you have I can give you a solution
Same Problem
Mar 21, 2009
-   i have an lg plasma(50pg40),then a front surround sound speaker system(subwoofer)there s no sounds from it,in tv ,the srs stereo tech is off,i cant change it to on,what should i do?
-   Guest
Solution #1
posted on Mar 03, 2009
Somewhat Helpful)
Dark_Orbit
Rank: Master
Rating: 88%, 10 votes
ok so you already established the optical connection from your TV to the hometheater system right? then follow these steps:
*first get look for any PRE-OUT terminal at the back of the amplifier
*get two rca cables (red and white to be color coded) and stick it to the PRE-OUT terminals of the amp.
*then get an adapter that will allow you to connect the headphones to the other end of the RCA cables (i think its available at radio shack).
*make sure that your headphones have volume adjusters. because the volume level on the PRE-OUT is fixed and cannot be adjusted using the amp. the only way to adjust it is by adjusting the volume level on the headphones. ü
after this you should be good to go...TC!
Comments:
Mar 09, 2009
- simple steps.....well thanks anyways
Was this helpful?
Yes
No
Popular Solutions for Home Theater Systems
Questions and Unsolved Problems for Home Theater Systems
Answer
this is all new to me. i'm wanting a surround for my basement tv but i don't want all those wires... (More)
Answer
The headphone jack doesn't work on my Koncepts SME 359 electric drum set. But while plugged in to... (More)
Answer
I have a lg 42" LCD and how do i hook it up to the RCA RT2600 with the digital audio
Describe your Home Theater Systems problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Home Theater... Experts
Top Audio & Video Equipment Repairmen
in , PA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
