Question about Gateway MX6124 Notebook
Cannot connect to the internet
Want connect wirelessly to internet its not my provider service already had that checked i had a restore recovery disk done on it and now it want connect to internet, before that it did connect
Ok... no offense but your statment makes no sense.
So you want to connect wirelessly to a router that is connected to the internet right ?
Posted on Feb 23, 2009
GM5084, recently recovered, will not recognize wireless or ethernet.
This will be a problem in BIOS.
You only need check the following if you cant install the driver Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider
Mar 03, 2013 | Gateway GM5084 PC Desktop
I would like to know when it say laptop with built in wireless. Does that mine i already got internet service on it. Or i have to buy USB modem.
Hello Blac,
All the laptops available in market have built in wireless 802.11 b/g/n or 802.11 b/g/n Bluetooth® wireless networking. It means that you can access the internet via Wi-Fi or through Wi-Fi hotspots. In wireless connectivity you do not require the wired connection to access the internet. In home you can connect the laptop via wireless connection using the home networking router available in market. The advantage of wireless connection is that you can use the internet in your home anywhere with in 100 meters of range with proper wireless signals. You will require to get the internet connection from the ISP(Internet Service Provider).
Please visit the link provided below for Home Networking Wireless Router :
http://www.netgear.com/home/products/wirelessrouters/
Jun 29, 2011 | Computers & Internet
Cannot go to the internet
first you must have an ISP Internet Service provider which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the net or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts
if you already have set up the internet
the driver should be on the motherboard disc or the one supplied by your ISP internet service provider
check the password make sure its exactly how you provided to your ISP internet service provider make sure the Caps lock is on/off which ever applies to your ISP contract
check your computers settings ie: firewall also he might have a default internet setting
check the leads from the modem/router whether usb,ethernet make sure they are not bad/faulty and have secure connections and try different ports
click start control panel administrive tools computer management device manager scroll to network adapters + to expand any yellow ! ? or a red x will mean that the driver is corrupt and needs to be updated
hope this helps
Jun 01, 2011 | Computers & Internet
I have a Toshiba A105-S101; just had to reinstall XP Pro on this laptop.. my internet is hooked up to my desktop and I need this laptop to connect to my wireless internet. What can I do to get it, Im...
Good day.
Since you already have a wireless connection, it would be easy for you to connect to the wireless network as long as you know your Network name(SSID) and wireless key which could be WEP or WPA. On the lower right hand on part on your desktop,also called the system tray,please look for the wireless icon which looks like an antenna with radio waves. Right click on that icon and please click "View available wireless connection," your network should appear on the list. Please click on your network name and click "Connect" to start your wireless connection. If it prompts for a wireless key or password, you could contact your Internet Service Provider to provide you with the password.
I hope this has helped you today.
May 12, 2011 | Computers & Internet
No conneck to internet
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
if you have already done this
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Apr 01, 2011 | Computers & Internet
Reboot hp laptop dv9730us without recovery disc. Need to do this because I cannot access my wireless connection anymore. It always says it cannot connect. i tried it with other laptops and it always...
You can restore your computer to the Factory State without the disk, provided you still have the recovery partition created by HP. Restart your machine, and tap F11 until you reach the Startup Repair. Cancel the AutoDetect and go to the list. You'll find an option that relates to restoring your PC to Factory state. Remember, you'll lose all data doing so. Let me know if you need more help
Oct 02, 2009 | HP Pavilion dv9730us 17" Notebook PC -...
I can't figure out how to set up my wireless internet.
To setup a wireless Internet connection you need the following :- 1. You need either a cable or DSL modem with a wireless router or a 3G wireless modem that connects to a 3G wireless network. 2. You need to signup with an Internet Service Provider. The Internet Service Provider may also provide this modem at a cost. 3. The Internet Service Prodider will provide an installation instructions/CD as well as E-mail setup. Have you already installed the wireless card driver on your computer? Can you give me details of what you have already done in regards with setting up the wireless access.
Jun 14, 2009 | Acer Aspire 5610-4648 Notebook
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Gateway MX6124 Notebook Logo
129 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
