Question about Whirlpool GH5184XPQ Microwave Oven
It is dead, acts as there is no power. Would the lockout feature if activated do this?
  • 52 Answers
Did it die when the door was closed with a bit of gusto, if so you need to remove the outer casing and check the internal fuses. these blow for unknown reasons.
Posted on Feb 23, 2009
My Magic Chef microwave say LOC when you try to start it
Sounds like the child-proof lockout has been activated. The manual would have instructions on how to release it.
Jul 16, 2017 | Magic Chef Microwave Ovens
When I attempt to enter anything with the keypad the display says "locked". Is there some way to unlock it.
Many microwaves have children locks. Of course they are for safety reasons. they are for tricking the little kids from playing with the big people toys.
Process A
To Turn the Control Lockout Feature On or Off:
  1. Make sure the microwave oven and timer are off.
  2. Press and hold the CANCEL keypad for 3 seconds.
  3. 2 tones will sound and "LOC" or a padlock icon will be displayed (indicating the control is LOCKED).
  4. Repeat to unlock. Again, 2 tones will sound.
Process B
  2. Press and hold the START keypad for 5 seconds.
  3. 2 tones will sound and "L" will be displayed (indicating the control is LOCKED)
Hope this helps?
Jan 12, 2016 | Microwave Ovens
Panasonic nn-t9455sfx has no power
If total dead look for the fuse inside and make sure the circuit it is plugged into is active(has power).
Dec 12, 2012 | Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwwave is not heating,
Hello
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
Oct 04, 2011 | Microwave Ovens
Mw oven totally dead. 2 year old panasonic
No sorry there is none... look what usually happens is the magnetron, or high power diode, or Oower Supply goes faulty, a magnetron can cost between $95 - $150, or more...and usually that is NOT the only part that will/would need replacing. Cut your losses, and get a firm "Quote" from a repair center, or get a new one, with a 5 year Warranty.
Mar 03, 2010 | Microwave Ovens
Microwave was run with nothing in it
Well sorry to break it too you, but the oven has been compromised. DO NOT USE! It doesn't turn on because the safety features have worked properly and have saved your home from severe damage. Lesson learned. /shrug
Jun 12, 2009 | Sharp R-930AK Convection/Microwave Oven
Locked ge spacemaker xl1800
This sounds like the "child lockout" feature is on. Does the door open, but the microwave won't work. Press the "clear/off" button for 3 seconds or so if this is what you're experiencing. If not, I apologize for wasting your time.
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sucka just plain died
If the light doesn't come on when you open the door, then it's dead, and it's quite possibly a blown fuse. It would be 15A or 20A white or dark gray ceramic type, located behind the control panel or by the door switches. They can be bought at local big box stores and appliance parts stores. If the lights work, but it won't respond, then you probably have a control panel or keypad problem. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. We repair microwave control panel assemblies for customers nationwide for $32.50 in most cases. I have a file of critical safety important safety information that I suggest you read before you proceed. You can find it by doing a search on Yahoo.com (not Google) for microwave circuit repair If you decide to send it for service, an exploded view of your control panel (all of which would have to be sent) is at http://tinyurl.com/y7e6um (originally here) http://www3.sears.com/Paul/Leadimage.asp?productTypeID=0123245&brandID=0582&modelDesc=MICROWAVE%20OVEN&modelNumber=56560502990&documentID=P9110178&documentTypeID=PLDM&documentClassCode=PM&titleType=CONTROL%20PANEL&titleID=00004& Post back if I can help further. Be safe!
Nov 13, 2006 | Kenmore 63792 Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
303 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
