Question about Frigidaire GLRS264ZA Side by Side Refrigerator
My ice maker won't make ice.I have a Frigidaire FRS26H5ASB5. Can you tell me what I can do?
    Problem Solver:
  • 7 Answers
I had the same problem with my ice maker.
I took it apart and cleaned the three switches inside the icemaker
The switches are not a high enough amp rating so they burn the contacts. Keep in mine cleaning is temp fix.
I did mine about 4 months ago and still working.
I have new switches now that I will be installing as soon as it quits again. About $9.00 for new switches and about $130.00 for a new Icemaker!
I hope this helps.
Posted on Feb 24, 2009
Put trays in to start making ice cubes and when the trays freeze the icemaker will start working. A friends did.
Posted on Sep 04, 2009
  • 2 thrust Mar 20, 2011
    On the back of the unit, check the water supply hose in the upper right corner. You need to unscrew 1 screw.....pull out the hose.....it is about 8 inches long. Check for ice blockage, run hot water through it and re-install.
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
What stop the compressor, water spilled on the freezer fan though the vent by the ice maker. help
Most likely the=> 5303918476 Defrost Control Board will need to be replaced. This board can be found inside the control panel inside the fresh food compartment. Unplug power and lets examine the board. Here is another source for the board 5303918476 Defrost Control Board Here is a photo of the inside of the control panel HERE and item location 23 is that board. I am here should you have questions, Sea Breeze
Soemtimes the defrost control board will show signs of failure with burn marks and heat damage but not always. It is likely this board is the problem and in some cases the start relay and run capacitor can cause these same symptons.
Jul 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
THE ICE MAKER SEEMS LIKE DOSENTT GET WATER
Remove the cover on the ice maker. Look on the main drive wheel for a missing tooth.
If that tooth is missing the water won't fill. Cheap part easy fix
Jul 07, 2011 | Frigidaire FRS3R5EMB Side by Side...
Fridgidaire gallery refrigerator ice maker Ice maker seems to freeze up and won't drop the ice.
Hi, The ice is clogging up the despenser. You need to open it and free it up.. Good luck.
Jun 28, 2011 | Frigidaire Refrigerators
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
4,279 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
