Question about Vertex FNB-27SM, YAESU,FT-26,FT-76,FT-415,FT-416,FT-815,FT-816,FT-530, 12v 1500mAh NiMH 2-Way Radio
Yaesu FT-26 I got a Yaesu FT-26 that is used. The Problem by it is that its frequence between 140.000 and 148.000, i cant get lower or higher than, I cant even send or recieve anything!!! even when i press the pedal, the green light doesnt light on... I tried to reset the frequence by attaching the jumpers 1,5,7 and 8 but nothing happen. I would like to know if someone can help me ??? Thank you.
  • lincolnoguei May 16, 2009
    I'm having the same problem for transmitting or receiving. It started to happen some days ago, and I'm thinking that something serious might happened. About the frequency, its possible to open it, and you would be able to transmit/receive up to 655 MHz!
    This I found in a website:
    RX-TX expanded range for YAESU FT26 handheld.
    Make FT26 open and locate straps 1 to 8 on the "CONTROL UNIT". Now you
    must close the following straps : 1, 3, 5, 7, 8. Close your FT26 and turn the
    power on while keeping at the same time the "TONE" and "REV" depressed.
    Now you need reprogramming low and high frequency edge :
    When "1" is blinking enter RX lowedge and then push "D/MR"
    ....."2"...................RX high.................."D/MR"
    ....."3"...................TX low..................."D/MR"
    ....."4"...................TX high.................."D/MR"
    You can reprogram your "ARS" like in the OPERATING MANUAL page 21.
    My choice was 136 to 180 MHZ in RX-TX and it work very good!
    F1LOU @ ON7RC
    Note: I haven't tried or verified this, proceed at your own risk. And
    do not transmit outside of legal bands!
I've tried this and it's not working for my radio at least.
I did the soldering straps : 1, 3, 5, 7, 8 (strap 9 and 10 are also soldered from before)
Turned it on holding D/MR + T + REV for full reset (or T + REV for partial reset)
Then turned off and back on holding both MT and MHz to open up the freq range.
Turned off againand back on holding RPT/SET to set the ARS range, but it only give me 1 and 2
CH.1 135.000 Press [D/MR] Lower Rx limit
CH.2 174.000 Press [D/MR] Upper Rx limit
So I can't set
CH.3 135.000 Press [D/MR] Lower Tx limit
CH.4 174.000 Press [D/MR] Upper Tx limit
No idea why realy.
Some sites suggest remove solder on jumper pad 10, and not soldering jumper nr 5, as far as I can tell this is wrong.
But I'm not entirely sure.
I've tried either way and none work, but without jumper 5 I couldn't enter TX RX setting by holding RPT/SET and turning on.
Any suggestions out there?
Posted on Nov 13, 2009
Same problem for me also blocking on the tape amateur 144/148 MHz not of emission nor of green reception led does not ignite malgres the modifs. Have a solution thank you
Posted on Jul 27, 2009
VHF/UHF RF Power falls to Zero when the Auto ATU tunr logo is on the display. When the tunr logo is off the VHF/UHF RF power is only 10 watts on 2M and 3 watts on 70cms. The Yaesu FT 857 D should have no...
Check for open or shorted Veractor diodes and steering diodes there may be no direct interaction as you say but if a diode is open or shorted the RF circuits might still be selected for the higher bands and the lower output power on your vhf/uhf is an indication of this.
If you do not have a service manual you can get one hear, you will likely kneed one
http://www.tradebit.com/filedetail.php/127575994-vertex-yaesu-ft-857-ft-857d-2005-service-repair
Good Luck Best regarsds Falco
Nov 04, 2013 | Yaesu FT-857D transceiver
Ft 2900r yaesu all i see on the screen is B0001 i can't see the frequency
Try powering the unit up while holding the Set/MHz button. I did that and it restored the display (and the rest of the radio's operation) back to normal.
The character codes are test-mode displays that correspond to frequencies (in MHz):
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
I haven't the foggiest idea why this isn't in the manual somewhere, or at least flipped back to normal by a two-key or three-key reset. 73, k2mct
Sep 16, 2012 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Yaesu ft 416 ver a2 need reset to get extended receive
You may find detailed instructions for this on www.mods.dk
Jul 03, 2011 | Vertex FNB-27SM,...
My yaesu-ft1500m have a bad RX on low frequency's and the RX is bether on higher frequency's, but on 144-146 MHZ RX is bad and on higher like 150 mhz is bether than 146, and on 160mhz is bether than 150,...
Sensitivity is a function of the rec rf amp and detector.selectivity is a function of image rejection and oscilator tuning accuracy. You have a good unit, needs aligned properly and troubleshot for bad components in reciever cktry
May 15, 2017 | Cell Phones
I need a new battery for a yaesu ft 26
Try "Batteries Plus" either online or possibly a local outlet. I found the batteries for my FT51 there and half the price of the factory ones.
May 19, 2010 | Vertex FNB-27SM,...
I have a FT-8900 and want to be able to open the AM side so I can use it on frequency 26.805 is there anyway it can be done
The Yaesu FT-8900 is a quad band FM transceiver only. It can not be modified to receive or transmit AM, SSB, RTTY or CW. It works on all or portions of 70 centimeter, 2 meter, 6 meter and 10 meter bands. The 26.805 Mhz frequency is 11 meters, so it is out of range of the 10 meter band in the radio, it is close. Even if able expand the transceiver, the AM / SSB mode commonly found in this band makes it impossible to use. Further, the radio is not FCC Type Accepted for use in this band.
Sep 05, 2009 | Yaesu Radio Communications
I need to replace the internal lithium battery on a yaesu FT-416 - how do I do this?
I have a Yaesu FT-415 and the same problem. My original battery is a SONY 1220-VJ2H (solder tabs, blue insulation on the outer edge and two stick-on paper insulaters) and is soldered in to the Control PC board (mounted vertically). I'm going to get a new battery and hopefully am brave enough to get the soldering iron to the board. It looks like you have to unsolder the board from the speaker to lift it up enough to get at the solder tabs on the battery, luckily I have access to a Pace soldering station with a vacuum pump. I'll hopefully try this next week and get back to you all.
Jun 17, 2009 | Vertex FNB-26,...
PPT works in the lower bands (under 148 Mhz) but not 156 range
Your radio has not been modified to transmit outside of the amateur bands.
Jun 07, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-29...
Yaesu ft-815
Double check that "TSQ" is not enabled. In the menus you can fine "SQL" and select the type of squelch. If you have "TSQ" selected you'll only hear signals from radios that a re transmitting the CTCSS tone selected.
Jan 21, 2009 | Vertex FNB-27SM,...
Radio Communications Logo
2,058 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
