Question about Lowrance GlobalMap 3500c Mapping GPS GPS Receiver
My Global Map 3500C shuts down after it has been on for several minutes.
DO YOU PROVIDE SERVICE IN ATHENS GA. FOR THE MACH 9 COIN COUNTER
Glory Global Solutions Inc. 3333 Warrenville Road STE 310
Lisle, IL 60532 Tel: 800.527.2638
Fax: 630.577.1270
info@us.glory-global.com Map of office location New Jersey 10 York Avenue,
West Caldwell,
NJ 07601,
USA Tel: +1 (800) 999 4510
Fax: +1 (973) 228 7114
Jun 30, 2015 | Retail Supplies
The Lowrance 3500C has a 1 GB capability. Does that mean I must purchase a 1 GB SD card for it? Can't find anything smaller than a 2 GB SD card, but will a 2 GB card cause problems?
No, this means the internal memory size is 1 GB. If this unit accepts SD cards, you can increase the map capacity. 2GB SD cards should work properly in the unit.
Nov 01, 2010 | Lowrance GlobalMap 3500C GPS Receiver
My engine shuts off while I am driving and then takes about 20 minutes before it will start back up. It also will start up and then shut off before I can get moving. Finally when I am driving sometime it...
the very 1st thing for you to do is have the OBD 2 electronic engine control system tested for trouble codes, whenever you have a stall like this there is almost always a code that is stored for the problem, which in your case will most likely be a crankshaft position sensor, but do the test.
Oct 01, 2009 | 2001 Pontiac Grand Am SE
HELP NEED CHEAT CODES!
Here you go:
MONEYBAGS 99999999 MONEY NEWWORLD AMERICAN PROSPERIY AGE'S SAMURAI ASIA AGE'S FEUDAL ASIA AGE'S BONUS MAP ANCIENT DAWN OF CIVILIZATION'S MAP MODERN Global Warming map BEYOND GLOBAL WARMING'S BONUS MAP HEREANDNOW RENAISCANSE BONUS MAP REBIRTH Renaissance II map SCIFI unlocks post global warming ages ex. map
Feb 01, 2009 | Video Game Consoles & Games
Lowrance Globalmap 2000
The screen is the weak point of the 2000's.  I have one myself, and without warning a number of "lines" appeared on the screen, getting progressively worse over time.
Perusing other forums, it seems we're not alone.  Unfortunately the only "solution" I've found thus far is to purchase a new head unit (eBay is a terrific source!).
May 08, 2008 | Lowrance GlobalMap 4800 GPS Chartplotter...
Lowrance 3500 color map GPS
Not sure about these but try holding the on / off button in for about 30 seconds. The TOMTOM resets when you do this, maybe the 3500 does the same?
Sep 17, 2017 | Lowrance GlobalMap 3500C GPS Receiver
Lowrance global 3200 gps
Go to this link; http://www.lowrance.com/Manuals/Files/gm3200_0105-981_092502.pdf Hope it helps :)
Mar 24, 2007 | Lowrance GlobalMap 3500C GPS Receiver
GPS Logo
35 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
