Question about GE Refrigerators
I HAVE A GE PROFILE REFRIGERATOR TOP FREEZER, MODEL# TBX22PAYMRAA THERE IS ALWAYS WATER ON THE SHELVES AND A LOT OF WATER ON THE BOTTOM UNDER THE VEGTABLE BINS. WHAT IS CAUSING THIS AND HOW CAN I FIX IT?
  • 2 more comments
  • susan_rodin Feb 23, 2009
    I DO NOT HAVE AN ICE MAKER.
    THANKS FOR YOUR COMMENTS THEY WERE HELPFUL.
    BUT I DO NOT HAVE AN ICE MAKER ARE THE SUGGESTIONS THE SAME FROM "JUMPTROUT51".?
  • susan_rodin Feb 24, 2009
    THANK YOU VERY MUCH FOR THE PROMPT REPLY. I WILL
    TRY THIS SUGGESTION.
    THANK YOU FOR YOUR PROMPT ANSWER. I WILL TRY THE SUGGESTIONS YOU MADE.
  • GE Master
  • 3,361 Answers
Two separate problems here.
One; remove the ice maker, then remove the back panel from the freezer. The defrost drain is probably frozen . It will have to be thawed. Then run a 1/4 cup of bleach through it.
Two. Water on the shelves sometimes is caused by the frozen drain line referred above.
But can be from a poor door seal on the fresh food compartment.
Check the sides and bottom of the door seal. It may have pulled loose from the plastic liner.
If it is warped and damaged it must be replaced.
Posted on Feb 23, 2009
  • steve
    steve Feb 23, 2009
    Yes, everything except the ice maker removal is the same.
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Top shelf of freezer and ice maker not cold and top shelf of fridge not cold. everything else on bottom shelves is frozen and cold .GE model GSS22JEMA
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
Blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
May 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
REFRIGERATOR dRAIN stopped up
LOOK INSIDE THE BACK TOP OF THE REFRIG. SEE IF THE DRAIN CHUTE IS THERE,IF YES YOU CAN USE A HANGER TO UNCLOGG IT.OR PULL OUT FROM WALL AND LOCATE DRAIN HOSE AND **** IT OUT WITH A SHOP VAC.,OR IF DRAIN IS NOT IN FRIG.REMOVE PANEL IN FREEZER AND THE DRAIN SHOULD BE IN THE MIDDLE BACK BOTTOM,IF FROZEN THAW IT OUT WITH HAIR DRYER,THANKS-MIKE
Mar 30, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
266 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
