Question about Panasonic KX-TG2740 Cordless Phone
I am trying to record the greeting message on model KX TG2740
Hi, I am on page 28 of the manuel to set the outgoing message. It says to press Function then press o or n as I am going throught the process. The o has 2 dots over it and the n has a hyphen over it. What do I press? I don't see those options.
  • buildbyowner Mar 16, 2009
    Lost my manual---and am trying to post a new greeting.
The Loud/Search button has small arrows. The O and N are up and down, the a is a right press.
Posted on Mar 10, 2009
WANT TO CHANGE OUTGOING MESSAGE ON PANASONIC KX TG 4131.
The base of your phone system is the KX-TG4131. The handset/base combination packs have a slightly different model number (KX-TG4132 for example). Assuming that you want to change the greeting of the answering system, you need to press Menu # 3 0 2 (when the phone system is in standby mode) from a handset. (Alternatively, press Menu and use the arrow keys to navigate to Answering Device. Press Select and navigate to Greeting. Press Select again and navigate to Record Greeting. Press Select and navigate to Yes. Press Select one more time. When you hear the beep, hold the handset about 8" (20 cm) away from you and speak your new message clearly. Press Stop when finished. The recording will cut off if your greeting is longer than 2 minutes. To exit the menu system, press Off. Make sure that the Answering system is on and your recorded greeting should play when you can't pick up the phone within the set number of rings.
See page 21 or page 33 of the manual. Panasonic has the manual here: ftp://ftp.panasonic.com/telephone/om/kx-tg4132_mul_om.pdf .
I hope this helps.
Mar 23, 2018 | Panasonic Lands Phones
Record message on Pansonic kxtg4021 cordless phone answer machine
With the phone in standby, press Menu on one handset. Use the Up/Down arrows to navigate to Answering Device. Press OK. Navigate to Greeting and press OK. Select Record Greeting and press OK. Highlight Yes using the Up/Down arrows and press OK. After you hear the beep, hold the handset about 8" (20 cm) away and speak your message. Press OK when you have finished the message. (The recording will end after 2 minutes.) Press Off to exit the menu system.
The answering system may need to be on for this option to be available. You can turn it on by pressing the Answer On button on the base. Alternatively, press Menu and navigate to Answering Device. Press OK and select Answer On. Press OK. Press Off to exit the menu.
The manual for the KX-TG4021 is available from Panasonic on the product site: http://shop.panasonic.com/support-only/KX-TG4021N.html . The direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf . See page 28.
I hope this helps.
Jul 09, 2016 | Lands Phones
Model KX-TG4021 - How do I put in a new answering message?
To record a new greeting, you must use the handset. Press Menu and use the Up/Down arrows to reach the "Answering System" line. Press OK and then navigate to the Greeting. Press OK again. Select the line "Record Greeting" and press OK. Select Yes to confirm recording a new greeting and press OK. After the beep, hold the handset about 8" away and speak clearly. Recite the entire message that you wish to record; the message must be under 2 minutes long. Press OK to save the greeting and press End to exit the sub-menu. Make sure that the answering system is on (and set to pick up on fewer rings than any other voice mail system, if your telephone provider offers one, for example). Make sure that the memory is not full. The system can only accept 18 minutes of recordings, including the greetings.
The manual for the KX-TG4021 is available from the product page: http://shop.panasonic.com/support-only/KX-TG4021N.html . The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF . (Note: there are several models that use the same manual.) See page 27 and the subsequent pages. The N indicates the region in which Panasonic sold the model.
I hope this helps
Oct 23, 2015 | Panasonic Lands Phones
How can i change my voice answering on the phone
Hello, Alex.
Press and hold [GREETING] until “Record greeting after the beep” is
heard.
After the long beep, talk clearly, about 20 cm (8 inches) away from
the MIC (microphone). • The elapsed recording time is displayed. • If you record for over 2 minutes, the unit will stop recording.
When finished, press [GREETING] or [STOP]. • The unit will play back the recorded message.
Hope this helps.
Jan 11, 2010 | Panasonic KX-TG2740 Cordless Phone
I have a Panasonic multi talk phone 2 line phone, model KX-TGA270S. Somehow , it shows "ringer off line2" I can't find a way to remove this. What does it mean? Line 2 still rings
I have a Panasonic Multi-talk KX-TG2740 and I need to change the outgoing message. Anyone know how to do this? (There is no "greeting" button as mentioned below).
Thanks!
Sep 07, 2009 | Panasonic Lands Phones
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
I can't remember how to record my outgoing message ?
here you go...
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Feb 01, 2009 | Panasonic (KX-TG1032S) Phone
Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Dec 16, 2008 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX-TG2740 Cordless Phone Logo
235 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
