Question about Food Mixers
Where do I get new blades for my Household Blending Mixer HA-3058
I need to know where I can get new blades. I dropped my ''chopping'' blade into the garbage disposal and can no longer use it. I have the Household Blending Mixer, model HA-3058.
Can someone e-mail me or post a suggestion?
  • akneisels Apr 08, 2009
    Thank you Megamixa! I did have an extra blade from a model I had before that burned out but gave it to my mother. I knew somebody else would make a same blade since my prior model was from a different manufacturer. Thank you for your help, now I won't have to buy another entire appliance.
It seems you can no longer buy the MegaMixa HA-3058 however Bamix sell a similar product - in fact apart from a couple of aesthetic modifications it seems to be the same machine....
They sell many accessories and you can get blades. Check:
www.bamix.com
www.bamix-blender.co.uk
I have both machines and the blades are identical and inter-changeable between models.
Posted on Apr 06, 2009
Testimonial: "Thank you so much Megamixa! I fianlly found the blade-only at Amazon! I can finally use it. Thank you so much!"
  • 27 Answers
Simillar chopping blade are available in the market, you can replace it on your own
Posted on Mar 06, 2009
I need a mixer blade for Andrew James hand mixer
Fixya does not sell replacement mixer blades.
Jul 29, 2017 | Food Mixers
Why won't the blades spin on the mixer ?
what sort of mixer is it? If it is a small hand help are the mixing blades fully inserted up to the little bumps on the side of the rods of the mixer blades where they attach to mixer. If a larger mixer like a kenwood, agin make sure the blade / s are properly inserted.
Aug 18, 2014 | Food Mixers
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
Please can u tell me if i can get the blades for this mixer and how much they will cost.
Yes the blades are available as spare parts for the Mixer. I suggest that you contact any nearby dealer of the Mixer.The price depends on the Quality and there are many makes of blades which is compatible with your mixer.
Mar 27, 2011 | Breville SHM2 Stand Mixer
My mixer blades are bouncing against the bottom and sides of the bowl and making a racket. The head of the mixer bounces up and down when I'm mixing very liquid-y mixes. When I made bread, I noticed a...
The BUSH on the spindle is worn out. You will notice that liquid blending might make the liquid to flow out through this . If so it is confirmed. This is usual as the food particles gets caught on and wear off the bush in due time.
the blade unit has to be taken out and the bush must be changed after choosing the right bush for the steel spindle.
You can confirm rotating the spindle and see if this shakes.
Hope this tip confirms the fault.
Aug 21, 2010 | KitchenAid Food Mixers
Blade stuck-can't remove for cleaning
Yes they can be tricky! The blade or dough blade/beater will always have this problem. I dont know of a "manufactured" way to remove this. However a flat screw driver that is carefully inserted into the opening at the base will remove it. With the codder pin positioned so the shaft and pin are going through the same direction of the opening of the attachment. Simply pul down on the attachment.I WOULD RECCOMEND TOWELS TO PUT ON THE MIXER BASE, since there is quite often alot of force need to remove them. This is is probably a good thing since you wouldnt want the attachment to come oof during operation. Hope this helps.
Thanks.
Jan 05, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Broken mixer blades on a bravetti 300watt hand held mixer
Bravetti Mixer Beaters 10+ Bravetti Products Shop, Compare and Save at Pronto.Bravetti.Pronto.com
Nov 02, 2009 | Bravetti 130 Watts EP524H Hand Mixer
Mixer runs, but will not turn beater.
You are correct, in the mixer head above the attachment hub is a gearbox, and there is a fiber gear meant to do just that should something similar happen, it can be replaced, I don't know price, but if you are careful, and fair mechanically, it is a straight forward replacement.
Dec 30, 2008 | KitchenAid K45SS Classic Stand Mixer
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Dec 30, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Instruction for household blending mixer
This is part of a kit called the Thunderstick Pro. You may have better luck looking it up that way.
Dec 29, 2007 | Food Mixers
Food Mixers Logo
1,214 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
