Question about Kenmore 74602 Gas Dryer
I have a knocking sound, not at the same point. Could this be a bearing?
  • 107 Answers
Possibly change in the baffles or something in the blower housing.
Posted on Mar 13, 2009
Dursngo sounds like a valve or rod when acelerate and running bad
If it knocks heavy under acceleration it will be a big end first or a main second. Disconnect each plug wire until there is no knock under acceleration and that will point to the piston and big end that is faulty. Remove the sump and that big end bearing and if the crank is still good replace the bearing. As you cannot get a single bearing shell then it may be a good idea to replace all the big ends . On the back of the shell will be the size of the bearing in thousands of an inch so if it says .002" then you need shells that are that much over size. Take a shell into a spares department and just ask for bearings that match that shell.
Jan 22, 2014 | Cars & Trucks
Knocking noise in engine of 2002 Nissan maxima
This is hard to say with hearing the noise but try to pin point the noise , is it coming from the top or bottom of the motor , the knocking noise could be a bearing in the lower motor or may be something else making it sound like a bearing,
Oct 05, 2012 | 2002 Nissan Maxima
2000 Chrysler Concorde has a knocking sound when it accelerates. What can it be?
Sounds like it could either be a spun out main bearing or camshaft bearing or it could be knocking from low octane gas, depending on how loud it is. A main bearing or camshaft bearing that is spun will make an unmistakably loud cyclic noise. While, the low octane gas will cause a softer random rapid knocking sound that sounds like a babbling brook. Check for codes in the engine that might explain why there is an octane related knock, like a knock sensor not working or something like that. Good luck on finding a solution to your knocking problem.
Nov 04, 2011 | 2000 Chrysler Concorde
Knocking noise only when its a rolling got new tires and front end alinement and the noise is still there.Turn the wheel and hear it good change out bottom ball joints knock still there
Sounds a lot like a pitted wheel bearing. Try jacking up the front of the truck and rotating the wheels by hand while listening closely. Some noise is normal but anything rhythmic points to a bad wheel bearing.
Sep 20, 2011 | 1999 Chevrolet S-10 Pickup
NOISE WHEN COLD THEN GOES AWAY WHEN WARMS UP,SOMEONE SAID MAIN BEARINGS GOING BAD
Hard to say over the internet but I will try to explain. If the noise is a distict KNOCK KNOCK and it sounds like it is coming from the bottom of the engine, then it most likely is a rod or main bearing. If it is a TAP TAP noise that sounds like it's coming from the top of the engine, then most likely a valve lifer is failing/failed.
the fact that it goes away when the car is warm, makes me lean towards a bad lifter. Normaly if a bearing is bad and knocking, the noise doesn't go away.
The KNOCK noise will be somewhat hollow sounding and the TAP TAP sound will be more solid. If the KNOCK KNOCK is solid, then a rod or main bearing has most likely failed to the point that a new/reman engine will be needed.
Jun 14, 2011 | 1994 Pontiac Grand Prix
Heavy mechanical knocking on final spin yet drum rotates freely when turned by hand and at low end drum speeds. Doesn't point towards the bearings. I have noticed that drum appears to be rotating slightly...
The knocking is the drum running out of balance due to the drum shaft being worn or corroded, or a worn bearing, a bearing can fail even though it may not sound noisy
Either way it is assoiated with the drum and entails a complete strip down, trust me on this, I do know what I am talking about.
Dec 03, 2010 | Zanussi FC1200W Front Load Washer
Have a 98 Jeep Cherokee,engine light is on ,has a knock when it accellerates, have an y ideas??? (sounds like engine knock).
have truck scanned for trouble code most auto stores such as auto zone/ advanced auto do it for free code gives u start point as to knock which is where code is coming from most knock noise is lower engine problems rod knock-wrist pin -main bearing going
Nov 26, 2009 | 1998 Jeep Grand Cherokee
MY NISSAN IS MAKING A KNOCKING SOUND COMING FROM THE BOTTOM OF THE ENGINE WHAT CAN BE THE PROBLEM
Knocking sounds in the lower engine area usually are from loose/damaged connecting rod bearings. Repairs are centered around resurfacing or replacing the crankshaft and the associated bearings. (many penny!)
Oct 27, 2009 | 2002 Nissan Pathfinder
Why do i hear knocking in my engine if i just replaced the heads?
.the knocking comes from the piston and rods sounds like the bottom end of your motor is shot you might have a spun bearing
Aug 29, 2009 | 2001 Dodge Durango
Kenmore 74602 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
