Timer keeps clicking round all the time, does not stop
The timer keeps clicking round all the time, does not stop, starts the cycle again
  • pparsons306 Feb 24, 2009
    Thank you for this, is this the selector switch. It is a W113UK, the switch is easily accessible and I have found the parts available for about £20. Thank you again
  • 54 Answers
You need to replace your timer, it controls the wash cycle. Depending on make and model they are relatively easy to replace and not to terribly expensive.
Posted on Feb 23, 2009
  • Sam Shamblin Feb 24, 2009
    Yes, the component that needs to be replaced sits inside the control console behind your cycle selector knob. You typically push it in or pull it out to start or stop the washer. Please be sure to unplug your washer before you start the replacement...not trying to insult your intelligence, you'd be surprised how common this mistake is...a truly "shocking" experience. :)
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it. watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Kenmore dryer stopped working, still has power.
When the timer stops during the duration of the time set the timers cogged tooth gearing has stripped out. A new timer will be needed to get your dryer working again
Apr 07, 2010 | Dryers
Hoover 700LB Stops at the wash during the wash cycle keeps clicking then starts again at the spin cycle
It sounds like the timer is bad. Try another cycle like delicate, or normal, or heavy duty. If everything works on another cycle then it is probably your timer. If it doesn't work and you have the same problem, then it is probably an expensive fix. Best of luck
Mar 21, 2010 | Hoover HTC243 Top Load Washer
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Have an Admiral AAV8000 that does not stop
Sounds like you have a mechanical failure and the timer keeps advancing because the cam contact for the timer motor has to be manually shut down. Your timer is part 21001929
Jun 28, 2008 | Admiral AAV7000A
Keeps stopping
I have a feeling you are buying a timer board.
Dec 11, 2007 | Kenmore Elite HE4 Electric Dryer
Timer just spins round
yes it is the timer,i had the same thing happened to me on a hoover,i was told that the fault was when you turn the timer to a programme to do this slowly and gently and if you go pass a programme not to turn it back but to go forward again until you get to the right programme..hope this helps.all the a new timer may cost about £80 to £100.
Nov 19, 2007 | Hoover PE235 Front Load Washer
Timer clicks arround and arround
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
Jul 02, 2007 | Belling SGE12X Front Load Washer / Dryer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
