Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Freezer coats everything with a solid ice dripping down from shel
Just replaced timer but it is still the same
    Problem Solver:
  • 8 Answers
Check your defrost Heaters. Sounds like a familiar problem. Take off panel inside freezer. They are behind the freezer panel. Use a Volt/ohmmeter and check for continuity.
Posted on Feb 23, 2009
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
Hi I have a 1 year old Whirlpool french door refridgerator bottom freezer with ice maker. A couple of days ago I noticed a thick sheet of ice that formed on the bottom of the freezer. I cleared the ice...
Hello there,
When your refrigerator begins to have ice at the back, it is known as ice build up. There is no leakage anywhere, it is just that there is a component or the other that is being faulty inside the unit of the refrigerator. The defrost unit is where the problem is from.
The defrost process is done automatically and the process involves the defrost thermostat, the defrost heater and the defrost timer. Once one of them or more becomes faulty, ice will begin to form at the back of the refrigerator.
You will have to test the defrost timer, defrost heater and defrost thermostat in order for you to be able to tell which is faulty and need to be replaced.
You can go through these tips if you intend to fix this yourself. Defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat http://www.fixya.com/support/r10513650-replace_defrost_thermostat defrost heater http://www.fixya.com/support/r10523771-test_defrost_heater http://www.fixya.com/support/r10523754-replace_defrost_heater defrost timer http://www.fixya.com/support/r10523722-test_defrost_timer http://www.fixya.com/support/r10523742-replace_defrost_timer
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Whirlpool GX2FHDXVD (22 cu ft) Bottom...
Side by side refrigerator the refrigerator does not get cold but freeze works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Jan 01, 2010 | GE GSS25JFM Side by Side Refrigerator
Refrige and freezer do not get cold. Freezer is all iced up.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 16, 2009 | Refrigerators
Freezer coils freeze up solid with ice and have to be defrosted manually
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | GE Refrigerators
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer is covered with frost, I defrost it with a hair dryer and the next day it is back to the same as it was before
Aug 22, 2009 | Freezers
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice building up in fridge
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 12, 2009 | Refrigerators
Magic Chef RB19KA-4A not cooling. Compressor is running as I can observe frost on the copper tubing. Condensor coils were cleaned off of dust but overnight the freezer temp only got down to 45 deg F. Any...
It was determined to be a malfunctioning defrost timer. The freezer box bottom was removed (not an easy thing to do) and the coils found to be a solid block of ice. The timer would not start the defrost heater, hence the freeze up. The timer was replaced and the chill box is back in action.
Jul 22, 2008 | Magic Chef Refrigerators
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
105 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
