Question about Hobart Dishwashers
KITCHEN AID RESIDENTIAL BUILT-IN DISHWASHER, MODEL NO. KDS-18,
WILL NOT FILL WITH WATER. SUSPECT MALFUNCTIONING DUAL FILL VALVE. MODEL NO. KDS-18 WAS MANUFACTURED IN 1979. CAN YOU PROVIDE ME SERVICE MANUAL AND LOCAL PARTS SUPPLIER HERE IN MARYLAND? SERIAL NO. IS 221-812200.
4 Suggested Answers
  • 41 Answers
SOURCE: need users manual
parts are longer avaible it is obsalete
Posted on Dec 09, 2008
SOURCE: size specs
The measurements are difficult to find and verify. However, you can call Kitchen Aid. They will be able to mail or fax you a copy of the original user manual which should have the specs. The number is: 800-422-1230
Posted on Jan 08, 2009
SOURCE: Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Posted on Sep 06, 2009
My dishwasher is a kitchen aid and is leaving all the dishes and glass ware with grime and dirty what to do?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Jan 14, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen aid dishwasher
Jun 17, 2009 | KitchenAid Dishwashers
Jun 13, 2009 | KitchenAid Dishwashers
Older hobart kitchen aide Supera by hobart KDH7A
If i remember correctly, a KD7 was built in the 70's or early 80's, we used to service them before being sold to Inglis. Seeing it uses the same water solenoids to fill, and asuming it is filling ok, I would suspect worn arms and hubs. If it doesn't fill completely, the fill valve coils may be opening when they get hot from the water flow. The fact that you need a new rack would indicate wear thhoughout and may be too old to justify repair. Find your local Inglis dealer to check on parts availability.
Nov 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid dishwasher does not fill up with water.
yes, the problem is usually dirt in the valve or the water valve under the sink .
Nov 09, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
Dishwashers Logo
139 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
