Question about Honda Maxus Pressure Washer MX5222
No pressure with spray nozzzle open. engine stalls with spray noz
Honda 1600 psi pressure washer. When the spray nozzle is initially opened a short burst of pressure occurs then normal pressure from supply source is all machine will produce while running {gas powered}. When spray nozzle is releashed engine begins to stall and shuts off and nozzle has high pressure stored which must be releashed before engine can be restarted. Any help appreciated. Jerry from Ga.
  • 174 Answers
SOURCE: husky 2400 psi honda engine ran fine all day
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Posted on Jun 27, 2009
  • 97 Answers
SOURCE: Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Posted on Mar 19, 2009
  • 234 Answers
SOURCE: the washer will run about 2 min. then die. i have
It is possible that the oil pressure switch is not functioning properly or you have a lighter oil in the machine than is recommended.
Post a comment if you need more assistance.
Posted on Apr 27, 2009
  • 615 Answers
SOURCE: I have a Honda 3500 pressure washer. The motor
You need to start the unit and let it run for few minutes to get worm, make sure the water is fully open and the unit is fully cleaned. Push on the trigger on and off for few times not letting the unit shutdown, then start increasing the fuel mixture ¼ turn and push on the trigger again and see…this could be that the unit need service or the governor springs getting week if you got one on your unit…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 20, 2009
Testimonial: "The problem was the governor spring. Thanks"
catbob007
  • 70 Answers
SOURCE: Honda Trash Pump Model WT30X Stalling - 8hp
Their is an oil level sensor that lasts around 3 months of use. unplugging it would solve your problem But replacing it is a night mare. and if your oil runs out It's all over. if not the oil sensor, and your spark is constant Check your fuel system for water and debrie. Those pumps can run dry all day long.
Posted on Apr 06, 2010
Engine stalls when not using wand
Frank, either the unloader valve is out of adjustment(try loosening it off) or it is faulty and needs rebuilt or replaced as most people do.
Check the attached vids,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 15, 2016 | Honda Black Max 2600 PSI Pressure Washer
How do i prime my troy built 2550 psi pump for the soap?
You have to use a low pressure nozzle ( usually black with very large spray opening) With the low pressure nozzle siphons your detergent in with the spray water . If you are using a high pressure nozzle the soap will not prime.
Oct 26, 2014 | Garden
My honda excel 2600 psi pressure washer do not have any pressure when i squeez the trigger
Trash in, worn or damaged inlet and outlet valves are one possibility. Unloader valve stuck open or badly worn would also cause low pressure. Wrong spray nozzle size is another. Is the nozzle the right size for your pump?
Is water leaking from under the pump? That would show worn high pressure seals.
Apr 13, 2014 | Garden
Need help in getting Honda engine on NorthStar pressure washer to run.
Could be low water pressure I have found.
Also, I purchased a can of "stuff" at Lowes today which allows you to circulate a liquid substance which lubricates the pressure pump....the pump could be frozen up...
I have a rotating nozzle which I bought...and it had frozen up...this stuff works
Aug 31, 2012 | Northstar Pressure Washer 3000 PSI
Honda pressure washer manual
This is the best site to get ANY Honda manual, just send them a search request and within 2-3 hours you will hold your manual in your fingers.
Jul 28, 2012 | Cam Spray Cold Water Pressure Washer, 1600...
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
STARTS AND RUNS FINE BUT WHEN I START WASHING IT QUITS SPRAYING AND THEN BUILDS PRESSURE AND KILLS ENGINE
The reason it stops spraying might be a clogged gun, hose or nozzle-tip.
The reason for pressure buildup killing the engine might be a stuck unloader valve in the pump.
While you are checking each component of the "output" side, spray some penetrating lube into the "input" side of the pump (where the garden hose connects) and let it be working on the unloader valve.
Fix the spraying problem first:
Start at the nozzle and verify that it is open by using low-pressure air. Clean or replace as needed. Next check the hose (with nozzle and gun unhooked) and finally the gun/trigger mechanism.
All must be clear and open to perform correctly.
Next, pour a few ounces of power steering fluid (or similarly LIGHT oil) into the garden hose, attach it to the pump and turn on the water supply.
Leave the "output" hose, gun, etc. UNHOOKED and point the output port of the pump (where the high-pressure hose connects) towards a vacant, safe area.
Startup the engine and allow the oil in the garden hose to work its way thru. (About 1 -3 minutes of run-time.) Shut it down and attach the high-pressure hose.
Hope this solves the problem!
Oct 05, 2009 | Honda Pressure Washer PSI 3000
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
Honda Maxus Pressure Washer MX5222 Logo
375 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
