Question about Bernina Bernette 75
Bernette65 Do I have a lemon model?
Took the first one back to store, could not change needle to a different size. Had never sewn on it. Staff tried to get old needle out, could not, gave me a new machine. They tested the new machine, sold me an oil to pour on needle to get out of 2nd machine! Took it home, now this machine has lousy tension, thread jambs up. I have read, re-read and re-read the manual. Changed to expensive thread, etc, etc. I am trying to sew on 100% cotton. Is this machine garbage. Very disheartening and a waste of money. What do you think?
  • 202 Answers
Certainly a Bernette is a cheaper model than a real Bernina. But you should expect it to work properly. If they cannot hand you one that they have checked out and sewn with first then you should ask for reimbursement. This is just poor customer service to begin with. Really I very seldom see them for repairs. Take it in with you and they should sit down and show you whats wrong.
Rick
Posted on Apr 21, 2009
To sew a normal sticth what should the tension and be set on
there is no normal tension
that is what you decide with experience as it varies with thread size, material being sewn, needle eye size
as a guide when threading the needle , there should be a resistance when you pull the thread out to thread the needle
Sep 14, 2017 | Sewing Machines
Have an industrial singer 31K20 and plate no is Y9279937 and i am trying to buy needles for it. THe broken needle is 19/120 but i dont know if they need to be 135/17 or 135/7 - or doesnt it matter
any sewing rade shop will have an assortment of needles
they will be able to advise you on the correct needle to use for different materials that can be sewn
there is a site on the net that explains the needle sizing and uses
go google and type in--- needles for industrial sewing machines ---
pick the information for singer or read what is pertinent to singer
Nov 06, 2016 | Singer Sewing Machines
Missing Stitches
if you have verified the needle is the right one for the machine model and in correctly (long groove the correct direction), that the bobbin is wound and in the case correctly, try a different material and/or thread. If the problem persists, take the machine to a better mechanic/shop. It sounds like it is out of sync. (hook rotation to needle throw).
Jul 06, 2012 | Janome Sewist 525S Mechanical Sewing...
Needle won't pick up bobbin thread. Has been working fine all week. I changed the needle, took out the bobbin case, cleaned inside but there were no threads or lint. I rethreaded machine and tried a new...
Most of the time it is because the needle was inserted with the flat side facing you instead of away from you. And for the heck of it, put in a different needle, there may have been a burr or some defect on your new needle. Other than that, it could be your timing.
Apr 03, 2011 | Singer Confidence 7463 Computerized Sewing...
My machine is breaking the thread. I tried changing the needle, adjusting the tension, and different threads. It is still breaking the thread. I took the top cover off and oiled it and the bottom cover...
What needle size and thread are you using? The needle may be too small for the size thread or you are not threading it correctly.
You should also check the bobbin area to see if the thread is getting caught or snagged.
Jul 10, 2017 | Juki TL-98Q
My stitches are regular for the most part and then the stitch will be anywhere from 1/4 in to 1 inch. The stitching is very sporatic. It seems to work on cotton but I have a problem with pul material. I'm...
With any stitch problem, always a good idea to re-thread the machine - top and bobbin also - making sure the threads go into their correct tension areas. The next best stand-by "cure-all" is to replace the needle. Use one appropriate to the project being sewn. There are different size needles for finer through to heavy materials, and different needle types for lingerie fabric, regular cotton, denim, stretch etc.
Jun 15, 2010 | Sewing Machines
My machine is making a loud banging noise
These are the things that cause my machine to make a "banging" sound:
The machines with the horizontal/drop-in bobbin sometimes collect lint in the bobbin case.
Sewing fabric backed with a synthetic/foam/vinyl or adhesive.
Wrong size needle for the type of fabric being sewn.
Mar 13, 2010 | Sewing Machines
My kenmore sewing machine model 385.18221 is not really sewing. It seems like it is for a couple of stitches then the fabric goes down into the machine, threads r hung up in the bottom and when u get the...
Here are several solutions to try.
- Re-thread your machine. It may be threaded incorrectly (backwards).
- Raise your feed dogs if your machine has this feature.
- When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
- Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
- Change your needle, it may be blunt, bent, or otherwise damaged.
- Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
- Adjust the pressure of your pressure foot. It may be too light for your fabric.
- Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
- Adjust your thread tension, It may be too tight or too loose.
- Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: After changing your needle plate, check to make sure your needle aligns perfectly with the smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope these solutions help you.
Sep 24, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Needle jamming, threads all screwed up underneath, tension change
Try another authorized Husqvarna Viking dealer. Sounds like the hook/needle timing is off or the hook height. Or you could ask them to ship it back to Viking for them to do the repair. Check the Husqvarna Viking website for another dealer closest to you. You also might want to report the company to Viking. They do have to adhere to certain standards in order to keep their dealership.
Nov 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
124 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
