Question about Office Depot Ativa DQ60M Shredder
Auto mode the blades continue to turn
When I put it on Auto, the blades never stop turning.
  • loqo Mar 04, 2009
    I already clean de sensor, I have a Activa at-cc2008 and the motor just runs continuously in auto mode, HELP.
  • ywolk Mar 17, 2009
    At the one year anniversary of ownership, the auto turnoff stopped working. I need to turn it off manually or the unit continues to run until the overheat safety stops the unit.
  • 35 Answers
Unplug it! Clean the optics in the center where paper is inserted. You can do this with a cotton swab. Check to make sure no paper has lodged itself in the infeed center. If no optics, then check to see if a metal arm that activates the machine isn't stuck in the on position. This will be in the center of where paper is inserted. This repair might require the cover to be removed. Remember, unplug the shredder.
Posted on Feb 23, 2009
I put a new wiper motor and washer on my 1978 El Camino. They come on and work fine but won't turn off. could this be the switch or relay somewhere?
hi David.
this is all i could find out.
The fuse is the safety device that breaks the electric circuit if it exceeds the safe level. If your fuse blows then there will be no way to stop the electricity from reaching the windshield wipers. This will cause your wipers to constantly keep going. ... You can easily tighten it and the wiper problem should be resolved.26 Feb 2013
Windshield Wiper Blades Won't Turn Off - Auto Repair - Seva Call Blog ...
www.talklocal.com/blog/2013/02/s/auto-repair/windshield-wiper-blades-wont-turn-off/
or go to this link might help you.
wiper motor won turn off Google Search
Nov 18, 2017 | Cars & Trucks
Why does my generator start constantly?
if a lightning strike was anyplace close (30 yds) it's a safe bet your gonna have to replace the control board in generator also Id have a qualifyed tech ck out your auto transfer switch ,I bet he''ll find that you fried your coils on your switch too , do that before changing control board cus if ya hook up a new one to a bad coil ya just bought two of them
May 24, 2014 | Kohler Electrical Supplies
What makes the blades on a riding mower stop turning once the mower belt is disengaged?
The brake mechanism works when tension is released from the idler / cable. The brake is spring loaded to contact the spindle this stops the blades from spinning. I have attached a drawing showing the brake arm and where it can be found on the deck.
afzvk1vyaxgoaaaaaelftksuqmcc
Apr 15, 2017 | Poulan Garden
I have a goodman furnace model number gms80904bncc. When the temperature in house is met the blower continues to blow. Even if I put the thermstat in off mode the blower is still on
Hi #1 check thermostat : see if the FAN ON/AUTO switch is set to( auto ) and not( on)...If this is not the case turn the furnace switch off for 20 sec. and back on...did it stop? IF so the blower relay is sticking and must be replaced.
AUTO=BLOWER ON DEMAND/CYCLING
ON=BLOWER 24/7 all the time..
hope this helps
Nov 15, 2011 | Goodman Heating & Cooling
Where is the button/knob set up to play single song verses continuos songs from a cd on Pioneer cdj mk..
The button you need is the Auto Cue button, which is to the left of the top display. Press and hold to turn auto cue off, which puts the player into continuous mode. This button is also the Time Mode button.
Hope this helps
Jaye
Sep 17, 2011 | Pioneer CDJ-1000 CD Player
The IS - image stabilization option is missing from the menu
in auto it wont be there as its on by default, you cant turn it off. but put the camera in P mode or any manual mode and it will let you turn it from one shot, continuous or off.
Feb 26, 2011 | Canon PowerShot SX30 IS Digital Camera
Started shredding paper 4 sheets at a time. Auto function continued to run blades/motor even when paper was not being fed. Stopped using it and turned it to off position after several feeds (total of...
You should open the top up so you can see whats going on inside. take a good look at the pcb and see if its going "black" in any places(not a good sign) Remove any paper lying inside the unit...check and see if its paper, the pcb, or the motor that is "smoking"...have you ever lubricated the cutting blades.???
Once you determine where the problem is you can call Royal at 1-800-524-0799 for parts and prices if needed.
Sep 05, 2010 | Royal VF1012mx Shredder
Blades rotate twice but stop-motor continues to run, both forward & reverse mode its the same. Have tried to oil, unblock, run forward & back but to no avail. Can anyone help
Is the motor just humming after the 2 rotations? If you are over oiling the unit, tha shreds will soak up the oil and start sticking to the blades and begin growing a paper tumot in side the cutter shroud, whish in turn will start to slow down and jam the cutter asm and motor. Best to take apart and thoroughly clean.
Jun 01, 2009 | Office Equipment & Supplies
Pusher won't come out
Hi,my name is patricia ,and i found a solution,first the black button .the black vise grip put it in the blade while the blade is still in turn the black vise grip to the left while still in the blade keep turning to the left and the blade will come off of the black button.the black button do not come off or up.When you put food in but smaller pieces in and have all your pieces near you so you can continue to drop in in the processer while running it and can slowly put the long tube in to keep food from splashing do it slowly .hope that help
Aug 27, 2008 | Jack Lalanne Power Juicer (Stainless...
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
Office Depot Ativa  DQ60M Shredder Logo
317 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
