Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
I have the same problem with intermitant power, however, it does not make sense that the problem is in the upper powerhead (which is what a repair guy told me) because-- when I use the other attachements it is fine. The problem only occurs when I use the carpet (big)attachment so that the roller will not turn. Couldn't it just be in the area where the bottom of the handle attaches into the carpet attachment?
  • 744 Answers
You can test the auxiliary plug to the roller/beater attachment with a volt meter if you know how and take precautions. Check for 115-120 volts at the beater/roller attachment plug. If voltage is there and the beater/roller doesn't run, the problem is with the attachment. If not, then the problem is in the power switch or somewhere else that feeds power to the lower attachment.
Posted on Mar 28, 2009
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
How do I change belt in power head? Is there a
There could be 2 different ways to access the belt on the kenmore line of powerheads...
1) turn the powerhead over so that the bottom is facing up. IF there are screws on the bottom, remove them. There should be 2 either at the back where the rear wheels are, or one under the elbow, and one midway at the front under the lifter wheels. remove the screws, and there should be two tabs on the sides to remove the top cover. OR 2 tabs at the back of the unit near the screws to remove the top cover.
2) and this is the more common powerhead...
remove the light cover for the powerhead by pressing at the two sides and pulling the cover up. sometimes a screwdriver to pry open a little will help.
Remove the light bulb.
Remove the two screws.
Turn the head over and pry at both sides to pull the top cover off.
Good luck with either one.
Nov 18, 2010 | Kenmore Vacuums
The powerhead brush died. The vacuum works just fine, but the brush doesn't.
there could be 2 reasons for this problem.
one) the powerhead is dead legit as in there is no power coming to it or the motor is actually dead.
2) something jammed in the brush and popped the reset button. The reset button is a red button located as your looking at the back of the powerhead on the right side. Usually a red square. Push it and it SHOULD start up again.
That being said, if you have done the reset button and it still does not work, that unit I beleive has either a 2 or 5 year warranty (cannot remember dont have the documentation in front of me) and if it is still covered under warranty for you, take it to your closest Vacuum repair shop. Do take the hose and powerhead with the cannister unit.
good luck
Nov 06, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My powerhead shuts off on its own and then i must push the switch again.
Just had this with mine and I think it is the power wires embedded in the hose from the cleaner to the powerhead. Turn the cleaner on then work your way along the hose kinking it or moving it until the power head stops. Switch the power head on again and kink the hose in the same place, if it turns off every time like mine, that is where the break is. I haven't worked out if the cable cores can be replaced or repaired yet. Hope this helps. Chris.
Aug 18, 2010 | Dyson DC21 All Floors Stowaway HEPA...
I have a hoover celebrity QS wuith the power head. I have only used the powerhead for years purchased in 75) I removed the powerhead to use the brush and the power does not come on but if I put the...
You have done very well keeping this appliance working since 1975!!!
Lucky you!
I'm not certain you would be able to get replacement parts for this model any longer,
Maybe you will just have to continue with the powerhead only.
Nov 17, 2009 | Hoover Vacuums
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Broken belt
If you have the power head with the headlight, squeeze the sides of the upper part (almost like a superstructure,) where the headlight is located. It should lift off, allowing access to the screws to get the powerhead apart the rest of the way, and on most models it even has instructions on how to replace the belt molded into the plastic.
-R
Aug 03, 2008 | Vacuums
New Miele Red Star - Powerbrush not working
Wish you had listed the model number of the vac and of the powerhead. The plug going into the cannister, is it pushed all of the way in, also same for the plug going into the hose end? You can hook up the powerhead plug to a/c and see if it runs, if it does, then it is ok. Unhook the hose and plug and hook up a/c to that plug end and see if the powerhead will run, if not maybe the switch on the hose handle has a problem. Otherwise you have a problem in the cannister. If this is brand new, then it has a warranty, take in for repair.
Feb 21, 2008 | Miele Red Star Bagged Canister Vacuum
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
131 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
