Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Single lever moen shower valve -can't remove handle
I'm trying to remove the handle of my single lever moen shower valve. I removed the screw, but the handle will not come off. It seems to be still somehow fastened- not even budging ? Any suggestions??
  • lori_d_walsh Feb 23, 2009
    Thanks, I'm not sure of the model number, but the lever pulls outward and turns to 3 O'clock position for cold and 9 o'clock position for hot. It feels like I will snap it off, if I pull on it too hard.
  • Anonymous Apr 05, 2009
    have the same problem it won't budge at all
  • 547 Answers
If you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
  • albert getty
    albert getty Feb 23, 2009
    you may want to look for a set screw around handle thank you for useing fixya please rate me
  • albert getty
    yes there is most likley a set screw look at 6 o'clock
How do I remove the handle on Moen 2352 single handle shower
There is a allen screw under the handle some times covered by a red and blue plastic plug. Removing the allen screw allows the handle to be removed. Hope this helps.
Bob
Jul 04, 2014 | Moen 2352 Chateau Single-Handle Shower...
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
Can't remove valve on moen TL2377 shower faucet. I removed the handle by removing the screw. There is a chrome cup that I believe is a decorative cover over the valve stem. That is stuck and I don't want...
Take the round cover plate off and it will make getting that part off easier. You will be able to use a screw driver to help in removing it.
Be gentle and good luck
Apr 05, 2011 | Moen TL2377 Chrome Castleby Single Handle...
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Can't remove the handle on Moen shower handle... Seriously!!!
heat it up with a torch, or just break it off, you can call moen at that point and kindly tell them that your handle broke and you need a new handle and cartridge. or you can get a drill and drill the allen screw out, they are such a pain i usually break them when i can get them out and get parts for it then
Aug 04, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen Posi-Temp Shower Handle removal
I hate to say this but maybe the inside of the allen screw has been rounded out by a previous worker. You can drill the screw out and replace the handle with a new one. NOTE: Moen replacement parts are not cheap!
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle shower faucet, contstanly drips
Moen single handle - push pull has a screw beneath the handle cover plate. The Moen single lever handle has an allen wrench screw located under the curve of the handle. Once either one of these screws are removed, the handle should come off easily.
Once the handle is off, the water must be turned off and then you can remove the cartridge. Some cartridges are difficult to remove and may require a special tool. Most new cartridge packages have information on them to explain how to remove the cartridge.
Mar 12, 2009 | Home
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
1,653 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
